Question about Kenmore Dryers
I have a kenmore series 70 dryer (model # 78702894) gas dryer that is running but no heat. How safe is it for me to disconnect the gas line so I can remove the rear panel?
I am having a similar problem (I get heat for about 7 minutes then it stops heating) and just removed the back housing.  I did not have to disconnect the gas line to do this.  Just removed several screws. If your model is constructed differently and the gas line has to be disconnected, make sure you turn the gas off at the shut off switch back at the gas pipe.
Reading on your issue suggests to start by cleaning out all vent hoses to clear any lint obstructions.  I would start there and see if things improved then proceed to removing the back housing to get at the stuff in there.
Posted on Jun 25, 2009
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Gas Dryer - Kenmore 78702894 runs but does not heat
check for the clicking noise you will hear from the spark ignitor clicking. It will do that at the first 20 seonds upon starting your dryer
If not heard the ignitor is bad
Mar 12, 2010 | Kenmore 73952 Gas Dryer
you should hear a clicking noise upon starting it up with the dial set to heat
If not the spark sensor is bad
Mar 12, 2010 | Dryers
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
239 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
