Question about Yaesu Radio Communications
FT-920: When the TUNER switch is pressed, the
FT-920: When the TUNER switch is pressed, the xcvr goes into transmit mode and it cannot be ended without powering down. The mic PTT has no effect before or after.
  • 7 Answers
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Posted on Jun 26, 2009
When I press the speak button, It display's TX and the other radio displays RX
tx is the word for transmit and rx is for receive
if you press the talk button, the unit goes into transmit mode and is received in the receiver of the other unit/s
now that your statement has been clarified what was the question?
Feb 26, 2016 | Radio Communications
Bizhub 920
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
The soft switch you want is 03 -1-0
with the code it will be 03-1-1
1. "Service mode menu screen"
Press [07 System Setting].
2. "System Setting menu screen"
Press [01 Software DIPSW Setting].
3. "Software DIPSW Setting screen"
Press the [?], [?] or the numeric keys to select DIPSW bit number.
4. Press [On (1)] or [Off (0)] to set the selected bit number ON/OFF.
5. Press [Return] to return to the "Service mode menu screen" on which the sub menu was displayed.
Dec 07, 2013 | Konica Minolta Konica Bizhub Pro 920 Toner...
I don't have any audio on main or sub bands
Do you have Tone Squelch enabled? Is there a little "T.SQ" showing on the display? If so, turn it off and you'll be fine.
Apr 06, 2013 | Yaesu FT-920, 990, 1000, 2000, FTdx-5000,...
Have a dell latitude 600 d will not boot up goes right into bios mode and no modes work right back to screen windows xp thanks
Quite simple.. I've had several D600's.
You're not going to like the answer--
You OS is borked, or your hard-drive is damaged.
I'll go with the bored OS, as my D600 has survived years... What you can TRY:
Reboot the system, press F8 constantly as it turns on.. I'm mean constantly..don't stop.
1000x is okay..
It'll go into a grey screen, asking you if you want to boot into various optiosn... select, "Last known good configuration".
See if that boots. If it doesn't, do it again..select "SAFE MODE"... and you'll need to go into the recovery screen to "Restore from a previous state".
If that fails... Insert CD...reinstall OS :-(
Hope it helps.
Oct 19, 2012 | Yaesu Fc-30 Tuner For Ft-897 Ft-897d...
I plug my guitar to the amplifier and i get no sound at all..... only if i press the tunning button turns on & stays on for couple of minutes and then it goes off again....what can i do? P.S.: The...
The tuner on this is weird. It requires three presses of the tune button. Read your manual... One press turns on tuner and passes audio till it times out. A second turns on tuner and kills audio... the third press restores audio... Others have had the same problem understanding this three mode thing and the timeout in the first two modes is confusing when sound disappears.
May 14, 2011 | Takamine EG340CLH Acoustic-Electric Guitar
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Feb 24, 2009 | Vertex FNB-27SM,...
Durabrand wd810
Page 12 of the WD810 manual states: XM OPERATION =SWITCHING TO XM MODE Press MOD button (6) shortly to select XM mode. =SELECTING CHANNEL UP/DOWN Press the TUN/TR>> button (17) or TUN/TRK<< button (16) to select the channel up or down. = SM MODE SELECTION Press LOC/XM button (2) to switch Category mode, Skip mode or normal. It is used as the selection of each: Normal >> Category mode >> Direct Tune >> When Category mode or Skip mode is engaged, the "CATEGORY" function is turned on in the display. When Category mode or Skip mode is released, the "CATEGORY" function is turned off. When Direct mode is engaged, "DIRECT" of alphanumeric display is turned on. How to direct tune (omitted)
Dec 28, 2006 | Durabrand WD810
Radio Communications Logo
852 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
