blue tint ghosting, seems like a convergence problem on my 2003 panasonic rear projection tv pt47wx53. Are their kits available to fix this or how can I fix it myself? Adjusting the convergence does not work. Thank you.
yes you can get the PT47WX49 convergence repair kit at the following link listed under their Panasonic kits category. The kits contain the two Convergence ICs and the feed resistors plus a CD which has the installation instructions. www.tvrepairkits.net
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic PT-47WX49 47 in.
Panasonic PT-47WX49 47 in. Rear Projection Television
I have a Panasonic PT-47WX49 and would like to know the original Panasonic part numbers, ohms/watts...
(More)
I have a Panasonic PT-47WX49 and would like to know the original Panasonic part numbers, ohms/watts ratings for resistors found on the circuit board as R7001 - R7006, R7048, R7049, R7050, R7053, R7056 and R7059. Thanks.
I am having a green and pink line at the bottom of the screen as well as a doublling of whatever is...
(More)
I am having a green and pink line at the bottom of the screen as well as a doublling of whatever is at the bottom of teh screen.
Have a LG rear projection TV 109cm analogue tuner 5yrs+, recently attached basic $70 digital tuner,...
(More)
Have a LG rear projection TV 109cm analogue tuner 5yrs+, recently attached basic $70 digital tuner, all stations appear but now have a bright flickering on entire screen on each channel. Do I need a to invest in a better tuner OR is it an issue with the digital signal & the LG rear projection tv technology?
horizontal movement in the picture like moving wood grain. While trying to perform a convergence the...
(More)
horizontal movement in the picture like moving wood grain. While trying to perform a convergence the green horizontal line is solid but has a secondary wavy line across with it. the vertical line is not solid but looks more pixeled and flickery.cannot go past the green convergence when pressing action
