Question about Acer 4220-2346 Notebook
Had vista reinstalled on laptop since then cd/dvd drive will not open or operate already removed filters do not know what else to do
    Scholar:
  • 34 Answers
  1. Get in to bios and try to open the drive.
  2. If it works in bios no problem with the drive. its software problem.
  3. if not take a paper clip and insert it in to the hole next to the open button on the drive.
Please rate me!!!
Thanks,
CF
Posted on Jun 25, 2009
Why is my computer not displaying the dvd/cd drive in my computer and not recognizing/reading cd/dvd even after I deleted the upper filter in Device Manager?
Like Vista, Windows 7 has some issues. That's why corporations, school systems and government entities are still on Windows XP. Only consumers have Vista and Windows 7 for the most part.
Since you've removed the Upper and Lower Filters, then remove the power cord, remove the battery, turn the laptop over and remove the DvD/CD drive. Open the lid and press and hold the Power Button for 30 seconds. Put everything back in (DvD/CD Drive, Battery, Power Cord) and reboot.
Apr 07, 2012 | Compaq CQ60-215DX Notebook
Sony DVD RW AW G170A not detecting disk Was working hit and miss with some discs recently that work fine on others pcs. Now shows no disk inserted when it is on all discs I use vista home premium. was...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
It could be a problem withthe lens, you should try cleaning the lens it's already gone bad there is no harm in trying
If you take a little risk can solve .
follow the instruction:
Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.
now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps you
Oct 12, 2011 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
I have a Gateway NV52 and the CD/DVD drive doesn't work. It worked fine for a short time, but suddenly stopped reading discs. It tries to find data on the inserted discs, but eventually just pops out the...
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Apr 30, 2011 | Gateway (5500652) (  5500652)...
I have similar problem First of all it tries to format CD when I putit in and try to open drive, when there is no CD in recorder it tells me to put disc to drive * instead of opening recordable disc option...
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps don
Mar 05, 2011 | LG Computers & Internet
My dvd/cd rewriter drive shows the disc is empty when i know its not
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps
Feb 11, 2011 | LG GH22LS50 DVD-RAM Burner
Hello. i have a dell inspiron 1525 laptop, my cd/dvd drive not opening and if you open my computer is not showing that it is there. how could i fix this problem? thank you
make sure that the cd/dvd rw reader is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don't forget to vote
Feb 10, 2011 | Dell Computers & Internet
I cannot read any CD/DVD despite the drive is correct installed according to the the list in the manager. The drive is: PIONEER DVDRW DVR-K17B ATA Device the computer a HP Pavillon dv6000 Notebook...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 01, 2011 | Pioneer DVR-107D DVD±RW Burner
My dvd drive wont work and it doesn't even appear in 'my computer'
Not sure if this is a laptop computer or a desktop but if you can remove the cover of the desktop and check the ribbon and power connectors to your DVD. Failing this your drive is probably bad. But in Vista I have seen CD_ROMs disappear and not been able to reinstall them till I formated and reinstalled Vista. This was an early glitch after Vista first came on the market. One way to test this is to get a bootable CD such as your operating system CD and try to boot from the CD at startup. You may have to go into the Bios and enable your CD as a first option boot up device. If your CD rom is functioning you should be able to boot up from the CD.
Oct 04, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
CD/DVD Drive missing. No UPPER or LOWER FILTERS
Shut down the laptop completely and then Remove the CD/DVD Drive from your laptop and restart it. Then See whether it notices it absence or not. Shut It down completely and then put the CD/DVD Drive back in and then Restar it and check again whether its appearing or not. if not then-----------> Go to BIOS and make sure that bios is detecting the CD/DVD Drive and its ON. It would Surely solve the problem. Install any New Firmware From For The CD/DVD Drive available on the HP website.
May 01, 2009 | Microsoft Windows XP Home Edition
The 'safely remove hardware' keeps removing my cd/dvd drive.
OK - hold on.
Before reinstalling the OS here is a quick somehting you can try:
Next time the message shows up. Remove the CD/DVD from the laptop. Give it some time without it and see what it does. After awhile, slide the CD/DVD back in. This may fix it.
Apr 07, 2009 | IBM ThinkPad R52 Notebook
Acer 4220-2346 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
