Question about Compaq Presario Notebook
My note book desk top screen is positioned in a
My note book desk top screen is positioned at a horizontal angle. I'm trying to execute the command to rotate the screen into the proper position again. What is the command to accomplish this?
    Sergeant:
    Champion:
  • 233 Answers
Hit ctrl-alt and up arrow.
Posted on Jun 25, 2009
No picture but at bottom of screen problem reads "Resolve bootstrap. failed". what does this mean?
*NOTES:(Commands input not executed by audio or verbal recognition unless spoken by *CREATOR using the *wake-up_command) rundle_32 is a windows extentionsion for windows PowerShell.
Distro is a linux Platform OS and the sandbox is a alt tool used to make source forges online also a tool in standard linux directory like example |:$BASH su -man cn- o- force t- all-do commands run commands execute commands write commands read commands `su launch GENOME shell l- sh bb args name shell $BUSYBOX or $busybox /sys/root/xbin sh- busybox l- GENOME terminal Alias root n-admini
Feb 12, 2016 | Panasonic Viera Tc-p65st30 65" Full 3d...
Samsung main power supply desk top monitorS20A350BS desk top
you must measure the output from your power supply see the diagram attached in the box. If some Voltage like +5vdc is missing you must replace the power supply. If the Monitor NOT turn ON try to test in another computer more easy. or go to the repair shop.Use the bottoms from the monitor and execute from the MENU make test.
God bless you
Jul 27, 2013 | Samsung Computers & Internet
Dear sir i have a compaq prsario desk top having vertival mounted cd drive. i tried to load small cd on this but it got stuck and cd drive is partially opening and the cd is not coming out. wat am i todo?
place the computer in a position in which the tray will be horizontal ..after that take a look near the tray it is a hole in which a sharp object inserted will open the tray manually ..in case it is not opening from the eject ...and remove the disk ..
if the disk will not remove ...turn the computer upside down but the tray to be in same horizontal position ..This happens cause the disk is not staying in place .....and the tray being in horizontal position and upside down..the disk will come out when the tray is opened
Jan 11, 2011 | Compaq Computers & Internet
Note Book no able to pass Image throgh pojector to screen
Hi brkhera. Did you try using FN + F5(twice)? (or maybe F6) after you connected the proyector? you will see either the same thing on both displays or nothing on the laptop and just the external monitor (depending on how many times you do it).In case you have a presentation using Powerpoint, first you need to make sure you have the video drivers installed (on laptops you'll have 2 - one for the laptop and the other one for the external display under Device Manager - if you have not reinstalled the OS this is not an issue) then if you do, you have to go to start - control panel - display - configuration tab and you will see the 2 monitors, one is the laptop and number 2 would be the proyector. Then you have to click on "extend windows desktop to this monitor" and that's it. Then on Power point you have to configure your presentation to display on the 2nd monitor and that's it. I hope this helps. Please don't forget to rate and write positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Acer Aspire One PC Notebook
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
  1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
Screen Method Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
  1. Before starting headlamp adjustment:
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    Mark a horizontal reference line on the vertical wall or screen.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
    Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
    On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
VOR type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check that no other load is in the vehicle other than a half tank of gas.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Need to adjusted headlights how do you do it on a
there are little screws with hex head or torz head. one for lateral, one for up/down.
shine on garage door.
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOL
    • VOR
    • Photometric aimers can aim SAE, VOL and VOR type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOL and VOR type headlamps.
    • Mechanical aimers can only be used with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
VOR type headlamps
VOL type headlamps
Mechanical Aiming
Jan 18, 2010 | 2000 Mercury Grand Marquis
I was running on battery then put the power lead in I heard a pop like a fuse blowing inside, now the Aspire one is dead. Is there an internal fuse?
Yes there is fuze inside. Actually what you have done is connected the power cord while your note book was running. In future never do like that otherwise you will ruine your note book. It is hard to open the Note Book than the Desk Top. If you try to open it yourself then be carefull not to damage it, otherwise if you can not, then take it to Mechanic and get the fuse replaced of the same value which is blown off.
Oct 13, 2009 | Acer Aspire One PC Notebook
Monitor showing imagens in horizontal position
Toshiba has a screen rotate utility. Try hitting Ctrl + Alt + Up Arrow on the keyboard.
Ctrl + Alt + Left Arrow or Right Arrow may work also.
Feb 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Compaq Presario Notebook Logo
113 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
