Question about HP DesignJet 1050c plus InkJet Printer
I have a HP DJ 1050c, the check Printhead path (2) comes on, but there is nothing blocking, and when I try to move the assembly, it is very rigid, when running the self test, the assembly moves back and forth in a jerking motion, rather than the fluid normal movement...help?
Replace the belt.
Posted on Oct 02, 2009
    Scholar:
  • 96 Answers
You need to replace the belt assembly. the jerking motion is caused by the build up of debris on the teeth of the drive motor. drive motor on the right side, belt and tensioner on left side. this is a difficult repair and it is getting harder to find the parts. if you can find a certified repair person, let them do the repair. should cost you $300-400. if they are worth a dime it should take less than two hours to perform this repair. make sure they clean the drive motor, replace the belt, clean the printer, lubricate the rail assembly. let me know if this helps.
Posted on Oct 01, 2009
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
We are receiving the error message Check Print Head Path Type 2 when trying to plot to our designjet 1050C. The carriage makes a slight clicking noise on the left side of the rod. Does anyone have a fix...
Upon power up, does the machine move the carriage assembly from one side to the other?
Generally, any message like that means the belt has a few teeth missing or is worn. The belt drives the carriage assembly to and fro. If the machine detects a slow down or stop, it will have you check the printhead path for obstructions. If there aren't any, then 9 times out of 10 it is a worn belt. Check for little pieces of black rubber under the belt and encoder strip.
I have also seen 2 other fixes: a dirty encoder strip (the plastic strip with little hash marks on it) and a faulty cutter. But most of the time it is the belt.
Apr 22, 2010 | HP DesignJet 1050c InkJet Printer
Error message reads "switch power off check printhead path type 2", any suggestions. I have cleaned along the track but problem persists on power up. Head alignment begins and after a short while the error...
there is an issue with your carriage assembly. it cannot move freely across the carriage rail assembly. the belt may be worn, lubricate the rail assembly or both.
Nov 16, 2009 | HP DesignJet 1050c InkJet Printer
Switch power off check printhead path(2)
Could be worn ink tube system and printhead cable snagging when the carriage moves, or dirty carriage support bar
Oct 12, 2009 | HP DesignJet 1050c InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check printhead path Type 1
May 20, 2009 | HP DesignJet 1050c InkJet Printer
Printhead
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
Oct 17, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
486 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
