Question about Dell OptiPlex GX260 PC Desktop
Turn on pc then beeps and nothing on monitor
Pc made by tiny when i swtich on it keeps beeping and dont get anything on monitor.want turn off unless i pull plug out .but if i press restart it stops then comes back on again
  • Tim Grayson
    Tim Grayson May 11, 2010
    So wait, when you hit the restart button the computer powers up successfully and it will boot into Windows? Usually when your computer is beeping like this at startup it is indicating some sort of hardware problem. Please let me know =)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Have your VGA card check by a hardware specialist and possibly the RAM. good luck
Posted on Jun 25, 2009
Toshiba screen is bleu and now i have a2nd monitor but now i dont see anything only grey light how do i reset it cntrol alt del dosnt work nothing happens
When you turn it on, do you get a series of beeps? These beeps are codes that are related to specific issues, so if video card, memory, etc does not pass the POST (Power On Self Test) then it will generate a beep code and these can be looked up on the web.
See http://www.computerhope.com/beep.htm for more details
Dec 20, 2012 | Toshiba Computers & Internet
MPC model D945GCZ serial:4237231-0001 INTEL
It should at least beep. Those beeps are diagnostic codes. Listen to the beeps and google 'bios error beep codes'. If it doesn't beep, the motherboard must be replaced.
Apr 20, 2010 | Computers & Internet
I turn computer on blue light on computer tower comes on monitor power **** turns blue and the on screen message going into power save mode and then nothing change motherboard battery and took out graphic...
Short of it being something simple like your monitor cable is unplugged, the more likely problem is that there's a fault on your motherboard or graphics card.
You should have an internal speaker connected to your motherboard, it should be giving beeps depending on what the problem is. If everything is ok then there should be a single beep.
If you are not hearing anything try removing your RAM and boot up, you should get lots of loud beeps, if you hear nothing then it's likely your motherboard is faulty.
Apr 05, 2010 | Dell Computers & Internet
Was trying to hook up hp printer. when i plugged
HP Printer driver problem. Disconnect Printer and see if the computer boots up properly now.
Mar 09, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Tower is beeping and monitor on/off switch is blinking
If the computer has been moved recently, I would chack the Video card in the mother board to make sure it is seated in the slot all the, Unless you have on board video.
Apr 12, 2009 | Dell Inspiron 531s Desktop Computer
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Is processor dead
Its good that it beeps without the memory that means the mainboard is trying to boot. Make sure to try each ram chip individually in both sockets (if you have 2). If that gets nowhere I would try another CPU next.
Dec 21, 2007 | Fujitsu LifeBook E7110 Notebook
Tower Beeping
As I can see the problem is not monitor but your PC if computer chasis beeping, depends on number of beeps the problem can be VGA card one long beep and 3 short or RAM if it beeping one by one short beep and finaly CPU if it continuosly beeps like police sirene. If beeps are pointing to VGA or RAM you must open computer chasis and plug out VGA and RAM and clean dust out of slots and of VGA card and RAM as well with painbrush and vacum cleaner and plug them back.
Dec 12, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Dell OptiPlex GX260 PC Desktop Logo
103 people viewed this question
Alun Cox
