Question about Panasonic PT-50LC13 50" Rear Projection HDTV
PT 50LC13-50 Panasonic TV
I replaced the Buld (AGAIN!!) and now the TV will run for 5 min & Turn off. The fan is working (it continues to run at turn off) and if I wait 2 minutes I can turn it back on?? This is the 3rd bulb in this TV since 2002 not a good track record for Panasonic. Help please or to the DUMP. P.S. Paid $3,ooo for it new. how sad Thanks Canu
  • Anonymous Nov 09, 2007
    Same issue. Replaced bulb once already.
  • 934 Answers
Going through bulbs that quickly would indicate to me a problem with the ballast or smps (switch mode power supply). It's not something you want to just run out and replace (expensive).. Call a reputable shop and tell them what you're experiencing.
I do know that they should check the value of C1330 in ballast circuit. If it is a .22uf, There is an upgrade kit available for it, panasonic p/n# LSUC0022
Posted on Nov 05, 2007
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Panasonic PT-50DL54 problems
there actually was a class action law suit on these tv's due to the bulbs.
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
there is the list of codes so yours is 7. Hope this helps.
Keep me posted.
Thanks,
Lee
Jul 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic TV shuts off after a couple minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
PT-56DLX75 turns off red light flashes. Replaced
You need to first CK power supply board for Bad capacitors they will be vented,swollen or puffed up on top ,if you do not see any then try replacing Ballast Board it is what Powers Lamp. Call Encompas Parts Dustrubtion for Part numbers and Prices or Visit teir Website online!
Mar 24, 2010 | Panasonic PT-56DLX75 56" HDTV
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
288 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
