Question about Safety 1st Acella LX Winnie the Pooh Standard Stroller
Squeaky Wheels I have a Safety 1st stroller (not sure of the model) that looks very similar to this one. The wheels squeak terribly. We have used WD-40 and oil but that has not helped. I want to remove the wheels, clean them and apply oil inside before re-attaching them. Can you tell me how to remove the wheels? Thank you!
  • Anonymous May 01, 2008
    hi i used to work at the bay and what you do is pop the caps of the center of the wheel and take it apart usually all it needs it to be taken apart wiped down and put it back together its when you use it outside dirt and water gets into the spaces. and also try exchanging the washers around hope all works out for you
    Problem Solver:
  • 12 Answers
To remove the wheels there are a plastic cap over the nut and if you can take that off that unfasten the nut and it should come off clean. The wheels might be squeaking because you might have them on to tight.
Posted on Dec 30, 2007
Squeak on rear wheels
Hi Ashley
At Dorel we never recommend oil based lubricants as they will add a sticky residue to the product which will attract more dirt and debris which in turn causes friction, leading to a squeaking noise.
We would advise cleaning of the wheels and axle is done with furniture polish or dry Teflon spray to remove dirt and grime and any residue which may be causing friction.
We would recommend you contact Uppababy for further advice
Nov 16, 2013 | Buck UPPAbaby Uppa Baby - Vista Stroller...
I need a new wheels for my stroller
This model is not available in the UK. Which country are you in - we will put you in touch with the customer care team for your country for assistance.
Feb 25, 2012 | Safety 1st Acella Sport Mediterranean...
Squeaky sound coming from car. got breaks checked and still squeaking. someone told me it is most likely the wheel bearing
It is possible that it is the wheel bearing especially if it is metal contact you are hearing. To be sure swap your wheels from back to the front and see if the noise transfers location. If it did it could be the wheels.
Jul 21, 2011 | Saturn Ion Cars & Trucks
Dryer makes terrible squeaking noise when running
remove the front cover and replace the drum glides that the drum rolls on at the front,they are very inexpensive and easy to replace you can try wd-40 to make sure this is your problem,if so then replace them because wd-40 draws lint
Mar 28, 2010 | Dryers
My Maclaren stroller has squeaky wheels, what can I do?
clean the wheels with soupy water, clean out all mud and things in between the wheels and hinges area. Check for loose parts, cracks and worn condition, repair and replace them if you can, let the wheels dry out then spray the hinges and any moving part and source of friction them with lubricant like W40.
Nov 09, 2009 | Maclaren Quest Mod - Scarlet Red Umbrella...
Hi, the wheels on my stroller are acting funny. The front left ones get stuck and won't move... stroller seems very hard to turn. Any suggestions?
hey try to add grease or oil in the joins of wheels it doing that due to fiction.good lucky any greet that baby angel 4 me.
Nov 03, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Where can I get replacement parts for Safety 1st Strollers
replacement parts for Safety 1st Strollers can be found on amazon. take a look here Amazon com Safety 1st Strollers parts. Hope this was helpful. cheers
May 28, 2009 | Safety 1st Two Ways Tandem 01-668 Twin...
Wheels that squeak and front wheels do not turn properly
Apr 21, 2009 | Evenflo Journey Elite Travel System - 3...
Safety 1st quick smart stroller instructions folds to a back pack
I have a second hand Safety First Quicksmart Stroller without a manual. There are 6 steps to unfold the stroller but I can't get past step 2, it's the part that allows the wheels to swivel around to face the right direction. I can't see a visible button or leaver. Any help will be gratefulyl received.
Apr 07, 2009 | Safety 1st Baby Gear
Safety 1st Acella LX Winnie the Pooh Standard Stroller Logo
929 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
