Question about Cameras
I have changed my batteries in my z1275 camera but it still won't power on ; what is the problem?
  • 393 Answers
You may be using the wrong kind of batteries
look at the owners maual for the type the camera requirs if you are using the right ones and you still have the problem you will have to contact the maker of your camera
Posted on Jun 25, 2009
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from Kodak EASYSHARE Z1275 12.0 MP Digital Camera providing that I am using rechargeable batteries inside the...
No. The Z1275 is not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera using a separate battery charger.
Aug 19, 2013 | Kodak EasyShare Z1275 Digital Camera
My z1275 will not power up. i have good batt.what can i do.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 11, 2011 | Kodak EasyShare Z1275 Digital Camera
My kodak z1275 wont turn on
first check wether those batteries are getting charged solution is to replace the batteries as you might nave not used the camers from quite long time
Jun 10, 2009 | Kodak EasyShare Z1275 Digital Camera
CAMERA TURNS ON FOR A SPLIT SECOND THEN SHUTS OFF
simply change the batteries as the batteries are unable to tale the load internal damage because of not using regularly.
May 30, 2009 | Kodak EasyShare Z1275 Digital Camera
Brand new long life AA batteries only lasting 15mins
Hi there.
This is a common problem with just about any digital camera out there (even my own).
After spending loads of money on top named brands and types i found that Duracell Alkaline batteries lasted just about the longest in my camera which is a Samsung S 500. Even so i would advise that you stock on them because the camera's do tend to eat the battery power.
Good luck and thanks for using FixYa!!
May 21, 2009 | Kodak EasyShare Z1275 Digital Camera
My Z1275 kodak camera's lens wont retrack. turn it on and then it goes right off.
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
May 04, 2009 | Kodak EasyShare Z1275 Digital Camera
OK, I had a similar issue with a M1033. It would power on then shut down right away. I turned it on and held the power button down. It stayed on as long as I held the power button down. So, while holding the power button down, I went into the camera menu system and chose the "Reset Camera" option. It appeared to do a hard reset and the camera has worked ever since. Hope this helps.
Oct 03, 2008 | Kodak EasyShare Z1275 Digital Camera
EASYSHARE Z1275 Digital Camera
KODAK EASYSHARE Z1275 is a peice of ****
Jun 28, 2008 | Kodak EasyShare Z1275 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
