Question about Aprilaire 600 Humidifier
Aprilaire 110 We bought my father in law's house after he passed away. The Aprilaire humidifier (Model 110) is attached to the furnace. When the furnace came on, I didn't see any water draining out of the exit port. I went to the plumbing supply house and bought a new water panel and a new orifice and installed them. When I plugged the thing in, it was running without the furnace being on. No matter if the furnace is on or off, the humidifier keeps running. What can be the cause of this?
  • Anonymous Dec 03, 2007
    I have the Aprilaire 760. This year (12-02-2007) when I turned it on I noticed that it stays on even when the heater is off.
    I do not know how it is triggered to go on. I noticed the outlet that the humidifier is plugged into is wired directly to 120V. The manual does not indicate how it is triggered on when the blower goes on.
    Problem Solver:
  • 7 Answers
Modle 110 has a relay in it see if it is stuck.Hope this helps
Posted on Feb 05, 2008
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Aprilaire Humidifier Model 560 - Humidity Not Rising in House
water trough on top filling up. do not clean it too much as crud distributes water across top better.
Dec 25, 2008 | Aprilaire 700 Humidifier
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Aprilaire 600 Humidifier Logo
433 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
