What could cause the left turn signal on a 1966 Bel Air to not work? The right signal works just fine. I just purchased this car 2 days ago so anything is possible. Also, the left break light is more dim then the right side, and is the same side that the turn signal does not work. Any ideas?
Check the light socket and the wires leading to the socket.The contacts inside are probably nasty looking green or have a white powdery looking corrosion on them,also check to make sure the bulb fits in the socket properly,it could just be worn out.The switch in the column could also have a bad or broken contact,but start with the simple stuff first.
