Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
I have a dwsr405eb0ww dryer and it seems that the heat is intermittent. I dried a load of cloths but...
(More)
I have a dwsr405eb0ww dryer and it seems that the heat is intermittent. I dried a load of cloths but the next load didn't have heat. I tried it again this morrning with a pair if jeans but 10 min later no heat
how do i open the front of the dryer to replace the gasket seal to stop the brown marks on my...
(More)
how do i open the front of the dryer to replace the gasket seal to stop the brown marks on my clothes and stop them from getting stuck in between the gap.
GE Dryer Model #DWSR483EB2WW Dryer tumbles, but there is no heat. Fuses are ok and air flow appears...
(More)
GE Dryer Model #DWSR483EB2WW Dryer tumbles, but there is no heat. Fuses are ok and air flow appears to be good. Do I need a new heating element?
Dryer turns on and dries fine, but makes a buzzing noise at knob. My elderly mother thinks it was...
(More)
Dryer turns on and dries fine, but makes a buzzing noise at knob. My elderly mother thinks it was hotter than normal when she put one pair of dry pants in the dryer to dewrinkle them today. I just used it recently for about 3 loads of wet clothes that dried fine. I think the dryer appeared hotter because she had one dry pair of pants in the dryer. Dryer has made slight buzzing noise on occasion for several months now. What do you think?
