The green light does not come on. it just stays on red.
SOURCE: The red light is staying on on my Acomdata 1TB
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it. If it does, your enclosure is bad.
SOURCE: running mac osx my acomdata external drive lights
This is the solution that worked for me.
Luckily I have another external drive of the exact same model that is working fine.
I used the power supply from the good working model and plugged it into the bad drive. The bad drive booted right up. Evidently the power supply was the issue, not the drive itself.
Even though the bad power supply had enough juice to light up the drive, it was not able to make the drive spin correctly.
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
SOURCE: red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
SOURCE: Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
