Question about Plantronics PL-CS55 Wireless Headset
Static on Plantronics CS-55
I had configured the headset correctly i believe. I can hear others and others can hear me, but the issue is the users say that i sound far away and very staticy. I have tried every different channel dial, and volume using both the large and small changes. Any ideas?
  • 83 Answers
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Posted on Jul 20, 2009
Can hear but other party cannot hear me
There are a couple of things you need to check. First, make sure it's connected correctly to the phone. This guide should help you with that:
Plantronics CS70N User's Guide
Secondly, the compatibility dial on the left side of the base has numbers 1-4. The indicator to the right of the dial needs to point to one of the numbers, never between numbers. Most phones operate using #1 for compatibility but you can dial in the others if you're still having issues. That should get you up and running.
Good luck from Headsets Direct!
Jan 24, 2012 | Plantronics CS70 Wireless Headset
I have plantronics cs 70 and this is connected to my cisco ip phone .the problem is i can't hear the other person on my phone but other persons can hear me ok.
You need to check all the locations of the dials and #'s, sometimes it is just a simple matter of turning a dial. Here is a link to the CS70 User's Guide that may help you.
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Jul 18, 2011 | Plantronics CS70 Wireless Headset
I am using my plantronic explorer 240 with my sony ecrisson vivaz mobile phone The sound is clear and people can hear me clearly too. However, my headset creates beep sound regularly when i am talking on...
If you are saying that it is the battery telling you that it is half when you start to hear the beeping, that may very well be the case. If it is the battery, you may need to keep it fully charged. The only other thing I know is that It will beep if you get too far away from the cell phone. Usually people put the cell phone on the same side as the headset. That way you are never out of range.
Mar 15, 2011 | Plantronics Explorer 240 Bluetooth Headset
I have Plantronics voyager Pro headset. The microphone is not working. The receiving end cannot hear me
Try deleting your Plantronics Voyager Pro from your phone and then repair them to each other. Sometimes this does correct any issues you may be having. The link for the user guide is included below.
Plantronics Voyager Pro User's Guide
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the price of a headset
anywhere from $11
http://www.amazon.com/Plantronics-M214C-Headset-Adjustable/dp/B000ANOY7M/ref=sr_1_1?ie=UTF8&qid=1294360480&sr=8-1
to $170
http://www.amazon.com/Plantronics-CS-55-Digital-Wireless-Headset/dp/B000C12GH2/ref=sr_1_3?ie=UTF8&qid=1294360480&sr=8-3
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
There is only one setting on my headset where there isn't a loud tone and the other person can barely hear me. They say it sounds like I am far away. What can I do to fix it?
The Plantronics S11 headset system needs to be plugged into the handset jack on your phone not the headset jack. There is a jack on the back of the S11 system where the curly cord from your handset will plug into. That should fix your problem.
Nov 11, 2010 | Plantronics S11 Headset
Plantronics PL-CS55 Wireless Headset Logo
655 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
