Question about Konica Minolta magicolor 2300DL Laser Printer
Can't make machine print Konica Minolta 2300DL
Will not print and this message has come up on screen "waste toner box full" what do i do?
  • mepulido66 Jun 25, 2009
    where is it? the waste toner? i figured that is what i needed to do, but where is it?
  • 3 Answers
As soon as you open the door on the right side of the unit the waste collection box is there. You will see it, it is the large strangely shaped item that extends from the middle top to the bottom of the unit.
Posted on Jul 08, 2009
    Problem Solver:
  • 7 Answers
You have to replace the waste toner, usually a consumible item else, you have to locate it and empty it
Posted on Jun 25, 2009
  • Hugo Girão Jun 26, 2009
    Haven't found any picture on the web where is the place of "waste box" but I can tell you is a white "bottle" with some "dust" inside and should be in a very accessible place.
    Regards,
    Hugo
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
Konica Minolta 2300DL waste box full message
remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
Place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer
Mar 22, 2008 | Konica Minolta magicolor 2300DL Laser...
My magicolor 2300dl printer is showing waster toner box full and won't print but the waste toner box is empty and new. Is there a reset button on the printer to bypass this error?
1. Empty the waste box.
2. Read p66 of http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
3. Identify the "Waste Toner Full Detecting Sensor" which tries to pass a light beam through the protruding plastic slot on the waste box that engages with the photocell.
4. Use a dry cloth to clean dust off the photocell transmitter and receiver and also off the protruding plastic slot, so that light will now pass through.
5. Refit the waste box and enjoy the $$ saving.
Sep 23, 2009 | Konica Minolta magicolor 2300DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Wast toner full
You need to replace the waste toner kit part number 1710522-001
Jun 10, 2008 | Konica Minolta magicolor 2300DL Laser...
My Magicolor 2300dl printer displays a 'Waste toner box full' message, even though I have just emptied the waste toner box.
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
Feb 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
Magicolor 2300dl
Clean the fuser, opc drum, and the basic inside of the printer with a vacumm. Suck don't blow with the vacuum.
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
381 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
