Question about GE Refrigerators
Constant howling noise. It sounds like a train in the distance.
I ordered a new motherboard to control the fan speed. Apparently this is a well known problem with this model refrigerator.
Posted on Jun 27, 2009
Constant speed howling noise from underneath 2003 Volvo S60 (base)
Open the oil filler lid and see if the noise goes away - or lift the oil dip stick. It could be a gummed up PCV system that causes pressure in the crank case that "whistles" when the engine is running.
By opening the lid or dip stick, you're letting the pressure out and the whistling should stop.
If this is the issue, FCP Euro has a PCV replacement kit for about $350.
Jul 16, 2017 | 2003 Volvo S60
My 2000 durango is making a loud howling/humming noise. It feels like it is under my feet when driving. Also when I hit 20 or30 mph. Please help. The rear end was leaking fluid. I had it sealed and fixed.
It sounds like the rear end ran dry and you need to have it rebuilt. To confirm this go for a ride with a trained tech and let him listen to it.
Jun 29, 2012 | Cars & Trucks
JUST GOT TWO NEW FRONT TIRES,(AND BALANCING). NOW THERE IS A CONSTANT NOISE COMING FROM THE FRONT END AND GETS LOUNDER AS ITS ACCELERATED. SOUNDS LIKE A RUBBING OR HUMMING NOISE.
Sounds like a wheel bearing or bearings going bad.
Humming or 'howling' noises are indicative of a bad wheel bearing especially on acceleration.
Good luck on this repair.
Oct 12, 2010 | 1999 Ford Taurus
The stopping distance d of a car after the brakes are applied varies directly as the square of the speed r. If a car traveling 40 mph car stop in 90ft, how many feet will it take the same car to stop when...
The stopping distance is proportional to square of speed.
that is 90ft proportional to 40^2 mph.
We can write as 90 = X * 40^2. ( X is a constant of proportionality) .
Which implies X = 90 / 1600 = .05625.
Assume S be the distance at which car stops when the speed is 90 mph.
S = X * 90^2. ( since X does not vary as same car is used)
=> S =.05625 * 8100 = 455.625 ft.
Thank you.
Jun 12, 2010 | Bagatrix College Algebra Solved Full...
Freeze howling sound
sounds like it could be the fan motor, perhaps it has a build up of ice on it Jeff, check that out first. is the freezer on the top or on the bottom of the fridge?
Oct 13, 2009 | GE Refrigerators
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Howling noise in the evaporator fan motor
Bad computer board in back of fridge, unable to control motor speed causing motor to hunt
Nov 02, 2008 | GE GSS25JEMWW Side by Side
Drive train noise
likely pinion bearing or carrier bearings. They howl, characteristically, and the howl changes frequency with speed. Do check the u-joints first, though.
Jul 22, 2008 | 2000 Jeep Grand Cherokee
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
