Question about Plumbing
Not running at251201-01
Not running at251201-01 I have power to motor....cap 271u , It ran shortly this morning
  • 832 Answers
Check if the motor winding is still OK. (Not grounded or
burnt windings) If still ok, replace the starting capacitor
and running capacitor of the motor. Start it up, see if
this will run normally. If it doesn't, check the centrifugal
switch. All this tips is for a capacitor start and run motors for pumpmotor service.
Posted on Nov 25, 2009
2002 vortex 4.3
spray the cap and distributor and all the HT leads with a water dispersant (wd-40 or CRC spray) Any moisture in the cap will cause a ht short circuit and any dirt tracks outside will do the same.
Feb 09, 2014 | 1987 GMC G2500
Will not start. motor hums
Turn the motor on then immediately help it by spinning the chuck. If it spins up to speed and runs OK, you have a bad start capacitor on the motor. If it still does not work you may have something jambed in the pulley/belt system on top or a shorted out motor.
Feb 21, 2013 | Craftsman 12" Drill Press (21914)
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
Our York P4HUB12N08001A furnace has an A/C unit installed and we are running it in cool mode for the summer. Yesterday, my wife noticed a repeated hum from the furnace, and the house was 4 degrees warmer...
A fan capacitor can be bad 'without' showing any visible defects - so - I would 'First" try a new capacitor, be sure to take the old one (after you've marked the wires for easy re-wiring) and get an exact replacement.
However, a fan motor running at a 'reduced speed' as yours is doing is - more than likely - because of a defective/shorted motor, although replacing the cap is a smart move (since it's possibly the problem here) and so much cheaper than a new motor.
I'm thinking the moter is shorted - but it's possible the cap is (shorted) - in which case it's possible that the shorted cap has shorted the motor too - meaning a new cap is essential when installing a new motor so it doesn't happen again.
You might look around in your electrical compartment (with the power off) for any sign of shorts, i.e. burnt wires, blackened areas around metal, etc. etc, although I wouldn't hold much hope for that being the problem. Note: if you find a short 'before' changing the fan capacitor - I would "still" change the cap.
If you find a short (in the electrical wires) - you can fix/repair it and 'clear the short,' and see if the motor will run correctly.
fyi - I was once told a 'shorted motor' will not run.
In my experience I've seen "plenty" shorted motors that 'run,' albeit usually at a slower speed - so don't let anyone tell you a shorted motor won't run.
good luck!
Jun 25, 2010 | Heating & Cooling
Nissan pulsar '88. replaced starter motor, then
Is it a manual, or an automatic? Earlier Nissans sometimes have a problem with the neutral safety switch (a device that keeps the engine from rolling over in gear or without the clutch depressed.) Generally, if their bad, they need to be a little warm before they'll start, like setting in the sunlight for a few hours.
Good Luck!
May 22, 2010 | 1988 Nissan Pulsar
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
May 21, 2010 | 1997 Volkswagen Jetta
The A/C unit is just humming could it be the capacitor
Take a look at the capacitor. If it is swollen, rusty, puffed up on top, or leaking it is bad. Sometimes you cannot tell by looking at it so you can test it. Using a suicide cord attach the aligator clips to the capacitor, Place the cap where if it explodes it's remains won't get on you.
TIP: (check to see if the leads are shorted to avoid any minor explosions.) Plug the cord into a 120 volt outlet for 3 seconds. This charges the cap. Tap the cap on an iron surface to discharge it. If it makes a popping sound it is good. If it does not hold a charge it is bad. Another way is to check it with an analog meter. Set the meter on the most sensitive setting. Touch the leads to the discharged cap. The needle on the meter should hop; reverse the leads and retry it should hop again. That is an indication of a cap that will hold a charge. If the needle never moves of course that is a sign the cap is bad. Also if the needle goes all the way over and stays, that is an indication the cap is shorted and therefore bad. The cap is designed to boost the power to the motor to get it going with multiple windings being powered up at once. As soon as the motor reaches running speed the cap drops out of the circuit and it takes half the power for the motor to continue running at optimum speed. This saves energy.
FYI: The old style shaded pole motors had no capacitor and so they used twice the power to do the same job.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2009 | Heating & Cooling
Truck tends to run rough in damp weather
i think you have a cracked distributor cap that is alowing the moisture to get inside of it. i would replace the cap. you can test this but beware if it is the cap the car will not start until all the moisture is dryed out of it. start the vehicle and spray just a fine spray of water on the cap if the vehicle acts up it is your cap or possible a plug wire
Apr 14, 2009 | 1998 Chevrolet K1500
Motor will not run
rollcutter, timer switch may not be switching on. If it is and power is present at the motor terminal, it could be the capacitor (starting capacitor). Faulty cap (open or short) will not kick start the motor to create torque and phase angle displacement with the main winding.
If however the switch ok, cap ok and still it won't run, could be the bushing or bearing at the end plate of the motor. loose bushing will not run the motor, you'll just hear a strong hummming sound.
Good LUCK
Apr 18, 2008 | Washing Machines
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
