How do I scan each picture into different folders to identify using a Toshiba canvio3.0 hard drive?
SOURCE: Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
SOURCE: I am trying to scan photos onto the computer
Try using the Dell all-in-one center instead of straight from the printer.
Start->All Programs->Dell Printers->Dell Photo AIO Printer 964->Dell all-in-one center
SOURCE: scanning picture using dell all in one 962
hi
try to do a flee power of the printer
check wether things are working or not after this .
if it doesnot work then try to uninstall and reinstall the system ....
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
SOURCE: I can't scan with my printer
try to remove the driver software and after a restart re-install the driver on the pc and see what happens.
