Question about Roper RAS8445KQ Top Load Washer
My washer will not drain completely - Roper RAS8445KQ Top Load Washer
  • 57 Answers
Your sump is blocked
Posted on Jun 25, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Washer won't drain completely
The balance sensor may be faulty - not allowing full RPM to draw the water out.
Check it/ replace it as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Kenmore Washer will not drain completely
Some machines don`t drain all the water out.
Is it your pipe which goes from the washer to the drain.
These pipes can get very smelly.
I suggest that you just run some soda crystals through the machine on a hot wash cycle.
please try this and let me know what happens
best of luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Laundry comes out very wet
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Regards,
Rick
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Jun 28, 2008 | Ariston Technologies AWD 121
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
