Question about Vtech i5808 Cordless Expansion Handset
Vtech 5808 my phone keep dropping the calls in the middle of a conversation and shows 'searching for base' all the time. i have tried changing the batteries, but still no gain.what could be the solution?
  • zsabka Dec 01, 2007
    Have same problem 2 my  additional handsets (Base is working OK) . Have reregistered them several times. Problem occurred shortly before warrantee ran out . Vtech has not been very helpful. Informed that I will need to by new handsets from them.
    Would recommend this product to any one. Will try to purchase new batteries. Don't know what my options are beyond that.
I've been having problems with short battery life on my Vtech
5.8 Ghz model CS5121-2. Tried "zapping" the 3.3 volt batteries, which helps for a while.
Determined (via DMM) that the base unit battery charger reads
10.45 volts DC no load - while the remote charger reads 12.5 volts DC no load. Xfrmr output is supposed to be 7.5 volts according to info molded into the unit. Might be the problem!!!
Posted on Apr 12, 2010
  • 3 Answers
This model of phone have serious problem regarding the battery. This phone use a lot of juice out of the battery. I'm pretty sure that when your battery is foul charge it doesn't do it. So the problem is in the handset. When your battery starting to get to low you loose your connection. Why?...Because the detection to LOW_BATT in your handset is not calibrate adequately. So it thinks that the batt is weak, to weak to make a conversation.
The other problem could be that your handset doesn't really foul charge your battery. So when you are to far from the base or talking for to long . There's not enough power in the battery to raise the output signal level(db) to your base.
Posted on Nov 21, 2007
How Long Do I Have To Charge My Vtech 5808 Battery?
Lithium batteries can be charged whenever you want for however you want. It is best to charge the phone overnight. you cannot overcharge the battery, and you do not need to deplete it before recharging it. Older batteries had a problem in which improper charging would damage them, but this kind of battery does not. Best of luck!
Feb 28, 2011 | Vtech 5808 Cordless Expansion Handset
Vtech 5808
Hi it sounds like the problem is with either the base unit board or the board on the phone.
Do you have one main phone plugged into phone socket and the other two are extra phones that just plug into mains and pick signal up off the main phone if this is the case then the problem will be with the main base unit.
So first thing i would do is check the cable to the phone from phone socket is secure and hasnt been trapped under furniture or somebody triped over it and damaged the wire.
If this is not the case then the problem will be with the base unti itself and as the waranty has ran out this usually means that the phone was only really supposed to last untill this time this is the same with most electrical unit you buy.
The problem could be something as simple as a bad solder on the main board near where the signal is sent from the base.
I would say that the actuall phone is not to fault because if the main phone was at fault then the other 2 would work fine.
If you are ok at taking electrical units apart and can test the board near the signal output on the base it might just be that the solder has failed after this time.
If the phone works for a short while before it dropps the calls then it more than likely is a solder problem the thing is it is difficult to get a spec sheet for these phones i will look and if find one let you know.
Have you tried plugging a different phone into the phone socket to eliminate a problem at the phone exchange let me know how you get on and ill let you know if i find anythnig for you ok
Dec 01, 2007 | Vtech i5808 Cordless Expansion Handset
Says it's unable to connect. I assume to base phone.
you have first to page the phone on basis set then you can use the hand set
Nov 06, 2009 | Vtech 5808 Cordless Expansion Handset
My phone keeps saying unable to connect
is your phone about a year old? It may be the battery. The vtech phones have weak batteries that clunk out after about a year and you'll get dropped calls, looking for base etc... The phone still appears to be working and the battery indicator tells you it's charged, but the battery is too weak to keep the wireless connection going.
Had the same problem and replaced the battery. budgetbatteries.com had the cheapest ones. But it's a knockoff, so I don't know how long it will last. So far it's been 3 months and the problems are gone. I would try that first and see how it goes. I paid about $15 including shipping. If you buy it from vtech it's at least double...
Sep 24, 2008 | Vtech i5871 Cordless Phone
Uniden dect 6.00
handset dies or cuts off frequently during calls or when talk is pressed to answer even when fully charged and right in front of the base unit. Beyond frustrating.
If I hadn't lost the reciept, I'd return this useless phone in an instant.
Aug 30, 2008 | Uniden DECT 6.0 Cordless Telephone...
We are having similar problem with vtech 5808
Install new batteries! Be sure to let them charge fully (overnite) before first use.
I have 5 of the i5808 expansion phones around my house - most about the same age - and they all started acting up ithin a few months of each other. I "experimented" with a new battery for one, and it solved the issue for that one phone...so I replaced the batteries in each of the others that were experiencing the problems. This was about 2 to 3 months ago, and all phones have been problem-free since the new battery installs!
Hope this helps.
May 19, 2008 | Vtech i5808 Cordless Expansion Handset
5808 drops call and starts searching for base
Got a wireless router? Change channels on the router off Ch6, the default channel and that may help your phone communication to the base station. I have had wireless phone customers lose their wifi when their phone rings, same frequency or intereference on that frequency.
Feb 13, 2008 | Vtech 5808 Cordless Expansion Handset
Stupid Phones
If you have two identical handsets, try swapping the batteries. If the problems moves with the battery, then it is old or weak and not holding a charge. That what it sounds like to me.
Hope this helps, and please rate my answer, good OR bad.
Oct 30, 2007 | Vtech 5.8GHz Analog Cordless Phone
Phones going dead
buy a new battery from ebay.
just type in the search box, 80-5808-00-00
(the battery number)
You should be able to get a replacement for around $6 incl shipping.
This worked for me anyway. (Same symptoms you described)
Jan 04, 2007 | Vtech IP5850 Cordless Phone
Vtech i5808 Cordless Expansion Handset Logo
403 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
