Tv was fine then boom! colors went weird and blurry, all red and yellow...
  • 8,617 Answers
Most likely the convergence ICs need repalcement.
Posted on Jun 25, 2009
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Around edge of tv the colors blue/red/green/blurry...
my 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do anything..how much will it cost to fix this problem?kodigaston@hotmail.com
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
BLURRY SCREEN
What do the colors look like? Does it look like you have more than one image, and the trailing edge of the second image is in a primary color like red or blue??
Bill
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
Sony KP61HS10 61 in - out of focus when first turned on
He probably went into the Service Menu by Pressing Display,5,Vol+,Power buttons and adjusted the red convergence and that may have lasted alittle while, but the problem seem to be going blurry and then when warming up comes back ok. This indicates a Leaky Capacitor. My question would be is it only Red that is Blurry or is it all colors. It could also be a CRT problem. Could you take a picture of it when it's doing it?
Oct 07, 2007 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
