Question about HP Photosmart C7180 All-In-One InkJet Printer
"push output tray all the way down"
Same problem. ug.
The tray is all the way down. Everything looks perfect. clue?...this did occur after a paper jam. But the entire paper came out of the jam, so I don't know.
  • 3422 Answers
SOURCE: Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
Posted on May 14, 2008
SOURCE: paper jam
I continued reading what others did with the same problem and one said to move the printer head to the left and look to the right way under there. Sure enough there WAS a tiny piece of paper in it and once we removed it, the printer spit out a small photo paper and all was corrected. I appreciate all of the comments posted on the internet... Thanks!
Posted on May 22, 2008
SOURCE: photo tray doesn't work
hp f 4235
Posted on Dec 25, 2008
  • 85 Answers
SOURCE: I'm currently experiencing a paper
try changing feed rollers in tray. To test or temporary fix remove the rubber tires and flip them inside out, then reinstall.
Posted on Feb 15, 2009
  • 6 Answers
SOURCE: Photo Tray Problem Error Messege Prevents Printing
kknjhinklo
Posted on May 28, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
My paper feeds out the back and I want it to print out the front. How can I set this up?
If the paper output tray is pulled out at the bak then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 28, 2011 | OKI Electric Industry B4600 Laser Printer
PAPER FEEDS OUT OF THE BACK INSTEAD OF THE FRONT
If the paper output tray is pulled out at the back then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 26, 2011 | OKI Electric Industry B4600 Laser Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Output tray
The tray above it where papers come out must be all the way down. In cannot be inclined at all.
Mar 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
My paper loader wont accept paper that is to say paper is no log
What I understand the paper tray is installed correctly.
Some machines have push sensors inside the at the end of the tray. Look inside the area where the tray goes in with a flashlight. Everything is mostly black so it is hard to see.
Look for actuators that need to be pressed. Locate the tray end area to see if there is a plunger that pushes in the switch actuator. Sometimes the plunger is missing on the tray, or the slide selector on the tray is not positioned correctly. I cannot see this tray so look for these common areas.
Sometimes you can gently move actuators up and down, and phsyicaly see if they fell out of postion or just completely broken.
Also, paper dust is common in these areas. If the sensor is dusty, the sensors will tell the machine there is a jam, if you can clean the sensors from debris even excessive tonor or developer that falls in these places a lot.
Good luck.
Oct 15, 2009 | Sharp Office Equipment & Supplies
How do I load paper to print?
Hi mattside92
1) If the paper support flap is open, close it, and then pull the paper tray completely out of the machine. Lift the output paper tray cover.
2) Press and slide the paper side guides (1) and paper length guide (2) to fit the paper size.
3) Fan the stack of paper well to avoid paper jams and misfeeds.
4) Gently put the paper into the paper tray print side down and top edge first. Check that the paper is flat in the tray.
5) Gently adjust the paper side guides with both hands to the paper.
Make sure the paper side guides touch the sides of the paper.
Note
When you use Legal size paper, press
and hold the universal guide release
button as you slide out the front of the
paper tray.
Note
Be careful that you do not push the paper
in too far; it may lift at the back of the tray
and cause feed problems.
6) Close the output paper tray cover.
7) Slowly push the paper tray completely into the machine.
8) While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap
Good Luck, and don't forget to leave a rating
Thanks
Mark
Sep 29, 2009 | Brother MFC-440CN InkJet Printer
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
GESTETNER DSc323 - SUPER G3
If you look at the paper exit you will see 4 white exit wheels
in the middle of the 2 center ones you will see that there is a black
lever. This needs to be pushed back into position so that it is horizontal to the exit wheels.
Hope this helps regards
Myott
May 28, 2008 | Gestetner DSc332 Copier
Printer not printing
If this printer has the duplexor feature there is a plate just above the paper tray and the paper may be stuck in there. Pull out the paper tray and look for a sorta blue button on the top right side inside of the printer. Push that button and the duplexor tray will drop down and that is where the paper may be hiding.
Nov 07, 2007 | HP LaserJet 2200D Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
304 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
