SOURCE: the hayward navigator gets enough suction, there
Too much suction pressure, rubber feet worn, or springs have popped out of feet
SOURCE: Sweeper does not reach end of pool
Check your returns. They may be getting a flo going in the pool that keeps the cleaner from getting to one end. Usually this is due to the current pushing the floating hose around pool. To fix this simply aim the returns down into the pool rather up on the surface. It sounds like you have enough hose. I hope this helps you good luck.
Testimonial: "Thanks for the answer. I adjusted 2 returns and now the vac reaches the end of the pool. THANKS!"
SOURCE: My Cleaner keeps stopping, if i move it along abit
If you think that your pool cleaner has got too much suction, you need to use the included water flow gauge to test the water pressure. If it is MAX or higher than the indicated minimum, you will need to get a regulator valve from Hayware (V094). This will reduce your water flow.
