Question about Fuji FinePix S5000 Digital Camera
Green AF illuminator
Hey anyone know how to disable this feature?
I am shooting in places where no flash is allowed and can't get the green illuminator to stop flashing in auto mode or sport mode any suggestions out there???
    President:
  • 423 Answers
Depending on your model, you may be able to go into the set-up menu and set the AF illuminator to the off setting.
Posted on Jan 22, 2008
TAPE
Posted on Jan 15, 2008
What is the red flash when I take a picture on my sony DSC-P200?
This is the AF Illuminator function. Turns the AF Assist light on or off. If on, the light automatically illuminates in dark shooting conditions.
This and other details can find in the DSCP200 User Guide
If this answer, help to solve it your question, remember to rate the answer. Good luck.
Sep 30, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
Each time I press the shutter button to take a picture the flash keeps flashing fast on and off 3 bursts of about 10 flashed then it takes a pic ??? help
The built-in flash can function as an autofocus illuminator. This helps with focusing in low-light conditions in the AF mode.
To disable this function, press the menu button, then select service1 menuitem, then AF illuminat., and finally, select OFF.
Aug 20, 2010 | Olympus EVOLT E-410 Digital Camera
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Flash
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Mar 09, 2008 | Olympus EVOLT E-500 Digital Camera
Help with red flash?????
Do you mean, the AF Illuminator (the bright orange/red light that appears before the picture is taken)?? If so, all have to do is click on menu, scroll all the way to the right (into the setup menu) and go to the camera icon. From there, go down to the AF Illuminator and switch it from "Auto" to "Off".
Hope that resolves your problem!!
Nov 29, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
AF Beam Cover
Check out LEE Filter or Kodak IR Filter
Place that filter over AF Sensor.
Or try ti find remote(TV/VCR/DVD/radio) control unit with a large filter over led.
You can still glue those broken part and glued it back as close as possible.
atdlee@netzero.com
Oct 01, 2007 | Canon Speedlite 550EX TTL Flash
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
AF Illuminator
The AF illuminator allows the auto focus system to focus on dark subjects. When the shutter button is pressed half way, the AF illuminator will light up the subject. The default setting is “ON”.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
AF Illuminator
The AF illuminator allows the auto focus system to focus on dark subjects. When the shutter button is pressed half way, the AF illuminator will light up the subject. The default setting is “ON.”
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Fuji FinePix S5000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
