Question about Mitsubishi WS-55511 55" Rear Projection Television
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of circuit repair experience. I just don't know where to start here. Help!!
  • 1 more comment
  • slickmonte Jun 25, 2009
    ok an update... been a while since I looked at it...
    just plugged it in, green light flashes for 45(startup) then once I press the power button I can hear a relay kick on.. after about 3-5 seconds I can hear it kick off... it does nothing else... I visually inspected the notorious caps and they seem in good shape... obviously looks cab be deceiving.. Where do I go from here?
  • slickmonte Jun 30, 2009
    I just want to make sure that is the issue. The green light does not continue to flash after I hear the relay kick off. The repair kit states that it corrects an issue where the green light continues to flash. It displays error code 23(short) Still same issue with the DM capacitors?
  • slickmonte Jul 01, 2009
  • Mitsubishi Master
  • 8,617 Answers
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
Posted on Jun 25, 2009
Power went out at home and tv will not turn on. it is a mitsubishi ws-55511. had problem about a month ago with it not coming on. repair man said it had a bad switch board. unplugged switch board and now comes on with remote only until power went out last night
Posted on Jul 12, 2009
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light blinks and cant turn tv on
If this is a WS-55511, it is probably caused by a DM module. Unfortunately, it is not available nor does Mitsubishi offer a rebuild option. Mitsubishi's phone# 1-800-332-2119.
Give them a call and you never know what they may offer you.
Hope this helps,
Skyassoc
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
530 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
