Is there a way to reset the radio to make it work because I unhooked the battery
You would have to get the code from your owner's manual or go to the dealership with verification of type car and they will give you the code.
If the stereo has CODE written across the screen you need to enter the security code which is usually on a plastic credit card style card which is found in the owner service and manual pack. Or it may just be written somewhere in the pack.
SOURCE: Unhooked the battery on 2004 Honda civic vx , now
Hi, check the service log book, the previous owner may have written the code there. The only other way to get the code is to take your car to the local Honda dealer. Hope this helps.
SOURCE: radio stopped working on my 2003 honda odyssey
Most honda's radios had a theft deterent system that requires a 4 digit code to be entered after power to the system is lost. If you do not have a code setup, look in your owners manual, some had a factory set code to unlock and allow you to set your own code. If not, you may need to see a dealer as they would be the only ones I know that would have the capability to unlock it.
