Question about Emerson Microwave Ovens
MWG9111SL This microwave worked fine for about 2 months, NOw it does not work. When you open the door the light comes on and the turntable turns. Shut the door and it stops. Is there anythng I can do?
  • Emerson Master
  • 9,098 Answers
If it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Otherwise, t
his is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Posted on Jun 28, 2009
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
