Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No spark 14.5 briggs I/C
Replaced mag, still no spark, is the wire to the mag suposed to have voltage when the ignition is on? it seems to be alys grounded.
  • 127 Answers
YOU NEED TO REPLACE THE COIL AS IT IS SHORTING OUT INTERNALLY
Posted on Jun 26, 2009
3.5 Briggs ,new coil ,ground wire unhooked,no spark
Re loosen the magneto place business card between mag. And flywheel retighten mag mounting screws remove business card shine up flywheel with sand paper with the mag off the motor clean rust off flywheel before remounting mag with business card.
Apr 25, 2017 | Briggs Garden
Kokusan denki
4 wire or 5 wire cdi makes a difference.? help me help you !!
Jul 14, 2014 | ATVs
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
Not getting spark in craftsman tractor lawnmower
How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
May 06, 2014 | Briggs & Stratton Briggs Stratton...
14.5 briggs no spark
To test for spark remove ground wire from ignition module and test for spark with a proper spark tester. If you have spark the module is good and the problem lies elsewhere. No spark and the module is bad and should be replaced
Nov 09, 2012 | Swisher T14560 T - 60" Trailmower with 14...
No spark at all on a old briggs and stratton. I
Hi Michael--
There are a number of things that could prevent your plug from sparking. Here are some things to check before you replace the mag.:
1) Make sure all control switches are turned to the 'on' or 'run' position.
2) Check the ignition wire's connection to the spark plug. The round clamp that meets the spark plug can sometimes loosen over time. You can tighten it by first disconnecting the spark plug, then gently crimping the end of the ignition wire that grabs the top of the spark plug with a pair of pliers and refitting it to the spark plug.
3) Is there a kill switch or a grounding lug that is stuck to ground, preventing the plug from firing? Sometimes those metal tabs that ground out the plug get bent into the 'off' position.
4) Are all the electrical connections clean and snug?
5) Are the flywheel magnets dirty? Roughing them up with sandpaper and wiping them down with some solvent is sometimes all you need to generate a better spark.
6) Check that the points are properly timed and gapped. Even if they are good, improper gapping can leave you without spark. They should be about a matchbook's thickness apart at top dead center.
--Hope this helps, Joe
Oct 08, 2010 | Troy-Bilt Pony Garden Tiller
Code P0300 misfired detected. I have cylinder 1 and 4 that doesn't spark. I'have changed one of the coil pack and still no sparks. I have voltage tested on the coil wire (brown) and it shows around 13 or...
sound like bad ignition module.make sure where coil pack set in module contacts is clean and making good contact.also make sure plugs and wires is good.
Jan 09, 2010 | 1997 Chevrolet Cavalier
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
There is no spark
I am unsure if your bike uses a coil or CID pack for the spark but whichever it has is most likely the cause. also if you have a kill switch then I would disconnect the wiring to make sure the switch is not grounding out the spark.
Jan 04, 2009 | 2006 Yamaha DT 125 X
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
155 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
