Question about Apple PowerBook G4 Mac Notebook
I can not get my 2.5 hdd caddy to work on my Mac
I can not get my Dynamode 2.5 hdd caddy external hardrive to work on my Mac powerbook and can not find any instructions on how to do so.If anyone could help it would be greatly appreciated =]
  • 30 Answers
If you used it on a PC you need to format it to a MAC. You can do this by going to disk utility and erasing it.
Posted on Jun 25, 2009
Operating instructions for apple superdrive
If this is an external Apple superdrive, then it won't work with any Apple laptops with an internal drive as the firmware detects the internal drive and will not run the external Apple device
Aug 05, 2016 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Tip
LCD Display Problems with Apple 15" PowerBook G4 Aluminum 1.25 GHz Mac Notebook
During boot-up, Apple logo heavily pixelated. After boot-up, display a riot of colors and vertical lines with nothing readable. External monitor works well
I'll appreciate any input.
~ JO
on Feb 08, 2008 | Apple PowerBook G4 Mac Notebook
I don't know how to connect an external modem to my PowerBook G4 12
You need an Apple modem.
https://www.google.co.uk/search?q=apple+usb+modem&espvd=2&source=lnms&tbm=shop&sa=X&ei=SyT2VN7mE9KXavCJgng&ved=0CAcQ_AUoAQ&biw=1920&bih=971
Jul 28, 2013 | Apple PowerBook G4 Mac Notebook
Hello i plugged in my laptop cable in my external hard drive by mistake and when i put the correct power lead the ehd makes a noise but not as before,i tried to open it to see if anything was burned but it...
You will have burnt out the electric side of the external drive and possibley damaged the harddrive.
Your best soultion would be to buy a hdd caddy and remove the hardrive from the enclosure it is in and place it into the new caddy, plug it into the pc and see if you can still use it and see and recover your files.
If the above does not work. There is a chance you have damaged the drive as well and depending on you level of computer know how you can rebuild a hdd i came give you full details but it is a very complex process and has to be done in a sealed enviroment which is dust free.
Mar 30, 2011 | Maxtor Hard Drive
Hi, my 500 GB drive lights up and hums after plugging into the USB port on my PowerBook, but the light is not flickering, and the drive is not mounting. I've tried using externally powered USB hub with no...
Hi Jerzy,
Generally when this happens one of three things is wrong.
1. The drive may have been disconnected without ejecting which can cause the file structure to be damaged, however you should still see some activity as the MAC looks for structure. If you see this activity for 5-10 seconds when you plug the drive in you should be able to retrieve your files with a copy of DiskWarrior which you can buy online or at your local Mac store.
2. The circuitry in the drive enclosure may have failed which can be repaired easily. Take the drive to your local PC shop, yes PC, Mac shops typically don't carry empty caddies. Ask the techs there to remove the harddrive from your enclosure and test it in a new enclosure. They will need a copy of macdisk installed on their pc to access you files properly but this will suffice for testing. If this works, buy the enclosure and your back in business.
3. The hdd inside the enclosure is dead/dying, if this is the case suggestions 1 & 2 will fail. Send the drive to a data recovery firm, I use www.armor-it.com and have them retrieve the files onto a new drive for you.
Let me know how you make out or if you need further assistance,
Chris
Jan 06, 2010 | Computers & Internet
Toshiba external hdd not recognised by any computer i try
connect your hard disk to other computer which has different os like windows xp then check it is detected or not if it is not detected then it has some internel issue.
Thanks
Jul 15, 2009 | Apple PowerBook G4 Mac Notebook
My laptop screen isn't working is it broken or have i just touched a button?
Easiest solution would be that the brightness has been turned all the way down. Try the brightness keys which are F1 & F2 on the PowerBook. Other more complicated problems are the display ribbon cable is bad, or the video port, or there is a display invertor on the motherboard that can go bad. The inverter can be replaced - there are instructions on the web for that. Have you tried hooking your computer to an external monitor? Is there a picture on the external screen?
Jul 05, 2009 | Apple PowerBook G4 Mac Notebook
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
Apple PowerBook G4 Mac Notebook Logo
244 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
