Question about LG WM-2277HW Front Load Washer
Leaking My washing machine is leaking I think when it spins.
  • kellnerchick Nov 14, 2007
    Our front loader also leaks during the spin cycle. After a load of laundry there is always a puddle of water on the right front side of the dryer. We double checked to make sure the washer is level and it is. Any suggestions would be appreciated.
  • sragan Dec 11, 2007
    I have the same problem with the LG Tromm Steam Washer. Only been using the washer for 3 months; washer smells musky, and it is leaking out of the right corner. When the washer stops, i have water dripping from the top of the gasket at the entrance to the drum. if i dont pull the laundry out as soon as it stops, i have to run another spin cycle to get the water out. I have had the repairman out twice and he can not find the leak. When i am done with my laundry I shut the water supply off and drain the water out of the machine. For the money we paid for the greatest and latest, they need to fix the problem. If you do a seach at consumer affairs, you will see all the problems associated with this washer. Next time I purchase a washer I will do more research. Sorry I can't help with your solution but if you find the answer please post. Sheila
Oops, our fault..... We had the repair man come out and take a look at the washer due to all the water in the right front after each load. Tunrs out it was just a hose on the back that wasn't connected tight. How embarrasing. The repair man was only here for max 5 mins. We checked and double checked all the hoses to make sure it wasnt something we did. Turns out it was us all along. Hopefully your problem is as simple as this. Our washer is working great! Good luck
Posted on Dec 15, 2007
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
Crosley Washing Machine leaking
cHECK PUMP AND ENSURE THE PROP CAN SPIN AND THERE IS NO **** IN THERE IF THERE IS CLEAR IT
Jan 24, 2009 | Washing Machines
LEAKY NON SPIN WASHER
sounds like you have a couple of problems, but the leaking is something you need to see where it's leaking from. as to the not spinning, it sounds like the transmission is bad
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Whirlpool heavy duty washer won't spin out the water and is leaking
yes you need to replace transmission and i think the bearinds and seal are all together on that machine
if not replace seal and bowl bearing
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
LG WM-2277HW Front Load Washer Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
