Question about Karcher 2500 PSI Pressure Washer
Excell VR2500 6.5hp
I have a excell VR2500 pressure washer ,after 1hr there was no pressure and two minutes later oil came out of aircleaner how can i fixit
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
I bought a troybuilt pressure washer used and i changed the motor oil and ran it maybe 5 minutes. later i checked the oil level again and it shot out the cap and i noticed the pump oil level is also...
if you left it sit for a while & did not turn the fuel tap off,it may have flooded and therefore the oil level would have risen causing the oil to over flow.
always turn the fuel tap off when not using your pressure wahser.
Sep 06, 2010 | Honda Pressure Washer PSI 3000
Excell vr2500 pressure washer ,no pressure, took off high pressure hose at bottom of washer , get water flow, but flow does not change when engine is running full throttle
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Jul 29, 2009 | Garden
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Changing engine oil on a gx390 engine for pressure washer excel
On the very bottom of the motor is a square plug to drain the oil. The machine must be elevated to allow the oil to flow into a drain pan. If you don't see a square plug then look for a small 1/4 inch tube coming from the bottom of the crankcase with a hex cap on the end of it. If you cannot find either of these, then you must turn the pressure washer on its side and drain it through the same plug you fill from.
Apr 23, 2009 | Honda Pressure Washer PSI 3000
Type of oil to use
I worked at a tool rental center while attending college and learned all about a variety of tools. We used hydraulic oil with anti-wear and rust inhibitor additives in our pressure pumps. Check at you local auto parts for this type of oil.
Dec 21, 2008 | Briggs & Stratton Pressure Washer...
Karcher 2500 PSI Pressure Washer Logo
1,976 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
