Cars & Trucks Logo
Tamoe Dreaneen Posted on Jun 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't abs light go off error code says pump
John d
Level 2:
New Friend:
  • Expert 73 Answers
  • Posted on Jun 05, 2014
John d
Expert
Level 2:
New Friend:
Answers
73
Questions
0
Helped
19539
Points
227
When a pump code comes on for the abs it is usually associated with the module connected to the pump. Most of the time either the relay controlling power to the pump loses it's continuity on the board or the connector builds corrosion and resistance in the terminals. Most of the time depending on the make and model an the exact code it can be remedied by purchasing a new or used abs module/ pump, repairing the old module/ pump, or just replacing with a new module/ abs pump(most expensive option). It is very common for abs relay/ pump codes to appear and end up relating to the power or ground circuit going to open( breaking continuity it frying a connection form resistance)
2003 trailblazer brakes quit working and brake light and abs light come onm when you turn car off and turn back on lights go off and brakes reset and work. Do you know what would cause this problem
Do you mean they are spongy or they quit altogether? If spongy, you probably have very low fluid in the reservoir and you are pumping air into the system (fill the reservoir and try again - however, may need a brake bleed, which is tricky with ABS systems). If the ABS is failing, you should see error codes (using a good code reader that will read the ABS ones). Lastly, your brake master cylinder may need to be replaced.
Check engine light is on and diagnatics show the error codes, P0722 and U2108
Definition of Diagnostic Trouble Code U2108 Buick: CAN Bus Error ABS Cadillac: CAN Bus Error ABS Chevrolet: CAN Bus Error ABS GMC: CAN Bus Error ABS Oldsmobile: CAN Bus Error ABS Pontiac: CAN Bus Error ABS Saturn: CAN Bus Error ABS
Definition of Diagnostic Trouble Code P0722 Category: Powertrain Definition: Output Speed Sensor Circuit No SignalNote: This definition of P0722 is applied to all manufacturers
3answers
What is the C0265 error code
The ABS EBCM anti-lock brake module is failing causing problems with the ABS pump running constantly, also will drain your battery.
  1. Remove the ABS fuse to prevent ABS motor burn out.
  2. You can still drive your vehicle with the module removed.
  3. We recommend covering the exposed surface of the hydraulic control unit with aluminum foil to keep out water and dirt.
Common Failures:
  • ABS Pump Always Running
  • Codes: C0265, C0267, C0268
  • Pump Motor Circuit trouble code
  • Power Relay trouble code
  • Valve Relay Trouble code
  • Dump Valves (solenoids) trouble codes
  • No Communication
  • Intermediate power loss
http://www.myairbags.com/dtc-code-c0265-abs-ebcm-light/
ebcm-abs-control-module-failure-code-dtc-c0265-c0267-c0268-pump-running-y52j5yjvtwyljepizajwhmfx-1-0.jpg
Abs subaru outback 1999 not light, no error codes but does not work.
Have the abs removed and checked for operation. If you press the pedal hard enough to produce a skid but it doesn't then the abs is working. Under heavy braking from speed you will get a pulsating feeling in the pedal as the brakes are released and then re applied very quickly. If you are finding that no mater how hard you press there appears to be no assistance to brake then the problem will be in the booster and not the ABS.
Car wont start 1996
the ecu controls the power to the pump and injectors. are you getting error on every test on reader that can be the ignition relay. its in the dash when you turn the key should hear it go click click. if just one click then one side of it has gone. there is the low volt side, ignition interior dash lights etc. high volts is ecu abs, air bags. etc. low volts go to the abs and ecu but when engine started it needs the high volts to be there to run.
Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
My clutch won't go down and won't go into any
ABS light coming on,For this get the Engine computer scanned.It can be error codes stored in computer.------------
For more details regarding this click the link below:-----
The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
And now for clutch not going in gears it can be faulty clutch issue or problem with clutch cable.This has to be inspected.For more detailed instructions regarding Peugeot clutch problem,click the link below:-----
Peugeot 307: Clutch will no go in gears?
http://whoisbyme.blogspot.in/2012/05/peugeot-307-clutch-will-no-go-in-gears.html
This will help.
Thanks.
3helpful
3answers
What does the abs light on mean in a 1996 chevy Corsica
Its the Auto Braking System.
This is the system that pulses your brake to reduce skidding when braking on gravel, ice, wet pavement...etc.
When this light comes on...more than likely it won't function correctly and your tires will lock up and skid.
Fixing the problem usually requires a brake job / brake replacement all the way around.
Hope this helps...
The other day I started up the car and backed up. As I was backing up I heard what I thought was the ABS pump activating. I thought to myself that was odd and then shortly after that I noted both the ABS...
Try removing the negative cable from your battery for about sixty seconds, re install and see if the light continues to show on. It may have set a "soft" code and won't return. If it comes back on, you need to take it to a shop and have it diagnosed. Some states won't let you pass smog with that light on, like California.
1helpful
I need the code to a 2000 yukon abs brake light to turn off after changing the brakes
If your ABS light is on, changing the brake (pads) won't fix the light.
There are several reasons for the ABS light to go on, and probably the most common is the connection to one of the four wheel speed sensors, or bad sensors. On most GMs, the sensor and wheel bearing are one assembly.
First, you need to get the error code read via the OBD2 plug. The dealer can do it of course. And many parts stores, such as AutoZone will scan for codes for free.
The code will give you a clue to the problem. Until the problem is fixed, the light can be reset, but it will turn back on almost right away.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
