Question about Ricoh Aficio 450 Copier
Error SC940 Hello... we have a Ricoh FT7650 copier and it was shutting off by itself every night (which I'm assuming is a power saving feature).  Well apparently one of our employees did not know that it was supposed to do that and taped the power button so that it could not turn itself off.  The next morning the screen showed an error "SC940" on it and it will not go away.  We have tried powering it on and off, we have unplugged it, we have tried everything we can think of.  Do you know how to clear the copier of this error?  Is there a way to reset the system?  Any help would be greatly appreciated as we try to call our service man as little as possible because he is not very good.  Thank you! Erin Wiley
  • Erin Feb 14, 2008
    Worked PERFECT!!!! THANK YOU SOOOOOOOOO MUCH!
  • 46 Answers
SC940 - Main Switch Abnormal (U.S.A. version only)
Definition: [level: A]
The Main switch does not turn off after sending the reset signal two times
in a row.
Possible causes:
· Main switch
· Main PCB
You must enter em SP mode and then turn off the main switch and on again.
Entering in SP mode:
Enter SP mode as follows:
1) Press the clear modes key.
2) Enter "107".
3) Press the clear/stop key for more than 3 seconds
Then turn of the machine, don't play around in the SP mode u can damage the Ricoh
Posted on Nov 08, 2007
Why is my Ricoh Aficio SP C411 DN laser printer shutting off soon as it is powered on
Go to user tools
than select the time for power save mode,reset mode set those timer off or for long time
Nov 10, 2015 | Ricoh Aficio SP C410DN Laser Printer
How do I correct my machine From shutting off my itself?
This is actually a power-saving feature. Keurig actually recommends you let it shut off on its own instead of powering on and off.
Oct 10, 2014 | Keurig B60 Coffee Maker
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Receiving a Communication Network Error on our Sharp MX 2300N only on the weekends. According to the tech this particular machine does not have a setting for work days only, which apparently is optional in...
Sounds like it's a network issue. If it's a CE-00 error, it's a definite communication error between the copier and the server.
To my best knowledge there are no optional work day on/off settings on this copier. There are power save settings, but nothing to shut them down or denote power save settings for weekends only.
It sounds like something in your server setup is shutting down or disconnecting during the weekends. I'd contact your IT department to find out if they have something set up that could be causing this error specifically for the weekends.
Aug 28, 2009 | Sharp MX-2300N Color Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh FT7650 Printing LIghtly - Developer Problem?
It isn't a broken corona wire. If that was the case, it wouldn't copy at all and you would have a few error codes as well along with a few sparks.
Dec 22, 2008 | Ricoh Aficio 450 Copier
RICOH FT7650
service fixed it today.
thanks anyway
Mar 12, 2008 | Canon imageRUNNER 5570 Copier
Ricoh Aficio 450 Copier Logo
233 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
