Question about Hardware & Accessories
All the sprinkler are on and the control box wont
All the sprinklers are on. and the control box wont turn them off or do anything . I turn them off by turning the water value off .Tryed unpluging the box to reset it and it doesn,t do anything. IT is a rainbird system.
    President:
  • 1,723 Answers
The solenoids are turned to 'manual on' at the solenoid. Turn it (the solenoid head) 1/4 turn CW and then the controller can take control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Imperial valet timer
Big box stores and sprinkler supply stores.
Aug 22, 2014 | ORBIT UNDERGROUND Sprinkl pop-up 4 adj"
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
The timer no longer plays all 3 programmed zones. It play only one.
Three things to look for:
1) If sprinkler turns on-off but doesn't advance to next zone, then Sprinkler Valve is suspect, and timer is good.
2) If sprinkler stays on all the time, or never turns on, then Timer is suspect.
3) If sprinkler turns on-off, but leaks when it's supposed to be off, then Sprinkler Valve is suspect, and timer is good.
Jun 24, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
Hi my nelson tractor leaks from bottom of gear box
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 29, 2011 | Nelson Sprinkler: Traveling Tractor
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Hardware & Accessories Logo
609 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
