Question about Canon PowerShot A95 Digital Camera
When I turn it on, the images don't appear on the screen. Everything else on the screen is fine (ex: when I go into menu, the menu appears normally on the screen, when I press the flash button, the flash appears on the screen...)But the images from the outside world don't. Instead, there's either just black, or fashing black and white.
  • sec_tao Jun 28, 2009
    Where can I find a canon service in Montreal? Do you know?
  • 34 Answers
Go to canon service, it's a common problem and they solve it free of charge
Posted on Jun 26, 2009
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
EX-Z750 LCD screen dimmed, then black
on the bottom of your camera by the battery theres a little hole sizes of a niddle,get a niddle and stick it in there press down and reset the camera to factory settings ,make sure the camrea is on when you press the reset.please leave a comment,vote,note.thankyou
Sep 13, 2009 | Casio Exilim EX-Z750 Digital Camera
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Home dvd video player
in DVD mode, open drawer, remove disc, close drawer,
press "sub woofer" for 5 seconds
Jan 17, 2007 | RCA RTD160 System
Canon PowerShot A95 Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
