Question about Coleman Powermate Powermate 5000W Generator
My dog chewewd up the wires on my coleman powermate generator model #PM0606750. Anywhere I can find a wiring diagram for it?
  • 98 Answers
Send me a large pic for the generator and i'll be more than glad to help u..
sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
Looking for parts for my yokohuma yk8500E generator, plug, air fliter
Same. I have one to repair, Most of the wiring for the ignition system is missing, andI cannot find a wiring diagram or workshop manual ANYWHERE.
Nov 16, 2012 | Coleman Powermate Premium Plus 6250W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
PM0557523 7500 WATT Vertex Coleman missing Capacitor.Need a wiring Diagram for AVR.0065649 Board I have a new capacitor comming and new Diodes.but I dont see where the wires conect to the AVR board?!
There are at least two AVRs for this generator. The original AVR has the diodes mounted on an external heat sink. The updated AVR has the diodes mounted directly on the circuit board. I have a schematic of the original model with the external diodes but it doesn't have the values or parts on the schematic. I will be more than happy to e-mail you a copy of what I have.
Oct 26, 2011 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 5500 watt output unbalanced
Get on their website and get the wiring diagrams. They should also have the resistances of the windings. Checking these resistances, may indicate a stator problem. Give the model number and it will be easier to help.
Jul 29, 2009 | Coleman Powermate Powermate 5000W...
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
354 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
