Question about Bodum Electric Kettle
Brokem switch on bodum kettle,
How can I get a broken switch on my kettle repaired?
I am experiencing the same issue with my bodum IBIS kettle. Can anyone explain exactly how to open up the base ? I cant see any screws ? only rivets ? thanks
Posted on Sep 29, 2012
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Posted on Jul 07, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: broken switch
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod.
Posted on Jan 02, 2009
yalmer
  • 552 Answers
SOURCE: siemens porsche kettle om switch problem
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Posted on Feb 09, 2008
slogan620
SOURCE: my red plastic on switch has snapped
you can buy a replacement from here
http://www.spares2go.co.uk/browse-DUALIT-72001-ON/OFF_SWITCH_-_RED-m125-p159253-s161139.htm
£6.95.
Posted on Oct 08, 2010
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
I have an earlier all stainless non-electric Bodum tea kettle
It will be hard to find a repairman and certainly not a DIY soldering project. That said, I would crazy glue the bottom rim thoroughly before giving up. Suggest get some idea from a reputable hardware/houseware store. Bev, Sorry no solution that's easy!
Feb 14, 2014 | Bodum Kitchen Appliances - Others
Dualit kettle on switch wont stay on
The switch is worn out. If you feel confident about taking the kettle apart and reassembling it, you can buy a new switch at the link below. Otherwise, take it to a shop to have it repaired.
Jan 18, 2014 | Dualit Axis Cordless 1.7 litres Cordless...
Kettle switch does not go up
If the switch is broken, you might find a repairer to fix it. But dont try any other way because of danger of shock. The kettle are very cheap these days , buy a new one.
Dec 04, 2013 | Hamilton Beach Kitchen Appliances - Others
On/off switch is BROKEN,HOW CAN I TURN THE KETTLE
Hanif, buy a new one because it will be difficult to find replacement and may even be costly. Kettles are cheap.
Oct 23, 2013 | Hamilton Beach 40870 Electric Kettle
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
Where can I find a replacement for the base socket?
Bruce, unfortunately Bodum has discontinued the parts to this unit :(
Apr 08, 2012 | Bodum IBIS 5500-01 Cordless Electric...
Kitchen Appliances - Others Logo
2,867 people viewed this question
Top Bodum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Bodum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
