KitchenAid KP50 Professional 5 mixer will not come on at all. When it was put away several years ago, it was reported to turn slowly, making odd noises, so i assumed a gear problem. I pulled the lower gear assembly, cleaned out the tons of packed grease, and looked the gears over, everything turns smoothly, and the gears appeared nearly new. Re-assembling, I tries the mixer, and nothing happened at all. All the wiring appears ok, with good connections. Bad motor?
It will not turn on, I checked the electrical outlet with another appliance it is not the outlet. ...
(More)
It will not turn on, I checked the electrical outlet with another appliance it is not the outlet. Is there a reset switch or fuse on the stand mixer? The cord is in good repair. What could it be???
I replaced the motor in our KP50. No issues, until I got the motor control in. The contactor arm...
(More)
I replaced the motor in our KP50. No issues, until I got the motor control in. The contactor arm will not close, or slide off the plastic slide attached to the adjust lever. Can anyone give me a simple process for adjusting this thing so it is off at off, and has all its speeds back...do I need to simply replace the control board too, or has anyone been able to get that contactor arm to ramp up and down the plastic slide the way it's supposed to? As far as I can see, that is the only issue. The governer is good, the motor and brushes are new...just this controller. Thanks for any and all help!
Was using the the grinder option on my heavy duty kitchen aid mixer and it suddenly stopped grinding...
(More)
Was using the the grinder option on my heavy duty kitchen aid mixer and it suddenly stopped grinding and wouldnt turn on again. Is this something i can repair myself or is it better to bring it to the service center. I've had this mixer for a while so the warranty has run out
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
