Question about RTO Atwood Water Heater - 6 Gal LP
Water heater turns on and then after a few minutes shuts down
  • John Coristine
    John Coristine May 11, 2010
    CLEAN AND HAVE THE THERMOCOUPLE CHECKED. ARE ALL THE OTHER LP APPLIANCES WORK NORMALLY WHILE WATER HEATER IS OPERATING?
  • RTO Master
  • 6,674 Answers
Are you sure there's water in it? May be on by-pass. Try opening pressure relief valve at top of tank slightly,and see if water comes out. If not, check your by-pass at back of tank for wrong position. Cold has to go in the bottom, and hot out the top. No valve open, or flow between them.
Posted on May 23, 2010
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
I turn off the main water valve to fix a leaking problem and now the water heater does not work. What is the problem, how do I fix this?
Turn the water valve back on, shut the power off to the water heater for a few minutes and let it reset it self. Push the reset button, and try again. Hope this helps
Mar 08, 2011 | Bosch Water Heaters
HOW TO RESET A LOCKOUT
Shut down the power and re-power it up again after a few minutes..
Feb 13, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
The unit starts for a few sec then shuts down.ptg 74.
A couple of things could be happening.
1. There needs to be more water flow at the faucet, a minimum of .75 gallons per minute. Low flow and pressure balance faucets and aerators will not work well with tank-less water heaters. You need all the flow you can get.
2. The flame sensor in the main control unit is week, this is a common issue with your water heater.
Clean the unit to establish adequate water flow. Remove all faucet aerators and turn the faucets on to activate the unit. If you still get the on and off problem you need to call the company for a new flame sensor and/or control valve.
Sep 02, 2010 | Rheem Paloma Tankless Water Heaters...
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
The pilot turns on but it clicks and then it shuts off the gas
The thermocoupler isn't sensing and shutting down the gas valve. Thercoupler needs replacing.
Nov 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Jul 16, 2009 | Rheem Tankless Hot Water Heater...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
RTO Atwood Water Heater - 6 Gal LP Logo
125 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
