Question about Hotpoint RVM1425 Microwave Oven
Acceptable distance from cook top surface to microwave?
Hotpoint Model RVM1325
Current distance is 11-1/2 inches
  • Hotpoint Master
  • 9,047 Answers
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Posted on Jun 28, 2009
My Kitchenaid microwave goes in "No Mains" mode when I utilize the back burners what is causing this I have the distance from the cook top 18-20 inches
My Whirlpool elite does the same thing when i have the exhaust running while cooking hot stuff. The phrase No Mains with a cartoon character jumping up and down on the lcd display. Tech support claims its low voltage. But my voltage is fine. Moving the plug to a different circuit doesn't help. Unplugging it for an hour seems to be a temporary fix because the problem happens again.
Sep 19, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
What is the recommended clearance between spacemaker microwave oven and range top
30 inch minum from the cooking surface to the cabinet above. See this link for installation instructions and more specifications.
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Store on top microwave OK?
Who or from where did you encounter this notion? Only if there are air vent slots on top that might get blocked, otherwise placing items on top is fine.
Oct 11, 2009 | GE Microwave Ovens
How do i remove my over-range Hotpoint microwave? Model #RVM1335WC001. I don't want to
You can download the installation instructions for the RVM1325 here.
Hopefully they'll be close enough to your model to help.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
ACWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2009 | Kenmore 69399 Microwave Oven
What is the building code for the distance from the bottom of the microwave to the cooking surface below? I have a Maytag microwave that was manufactured in May 2002 and a Maytag Gemini gas cooking stove.
You can check the owner's manual or installation instructions for what the manufacturer stipulates.
If you don't have them, you can download them here.
For building codes, contact your county or city government offices.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Maytag Microwave Ovens
Above range microwave
According to the installation instructions for this model, the distance from the cooktop surface to the bottom edge of the cabinet (and thus the top of the microwave) must be 30" or more.
Owner's manuals and installation instructions can be downloaded here: http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 26, 2007 | Hotpoint RVM1635 Microwave Oven
JVM1320WB installation manual
Try this URL:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670536.PDF
Its not exact to this model, but gives enough pointers to assist. Good luck!
Dec 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
614 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
