Question about HP Compaq ProLiant DL380 G4 Server
DELL DL-380 G5 "could not allocate page table memory" GSS 2.5
We run Ghost Solution Suite 2.5 and I cannot get this DL 380 to ghost for the life of me. I have ghosted other (older) DL 380's without issue. I'm sure this is going to turn out to be one of two things, either a BIOS setting or a GSS option switch.
I have already tried using -fnx -ffi with the same results.
  • nettek67 Jul 10, 2009
    Thanks for the assistance.
    However, running ghost with the -noide switch fixed the problem for me. I'm unsure why you say my ghost version is outdated. I just updated this from Symantec 2 months ago.
    Thanks again
    Problem Solver:
  • 17 Answers
First of all, Dl380 is an hP product.
Secondly your ghost version seems a bit old as ghost 14 is the latest version. Having said that the problem could be at two ends.
1. At the ghost side where your version doesnot contain NIC drivers for PXE boot and HDD drivers for imaging. To fix this you can try manually adding the drivers to the network boot or floppy boot diskette.
You can get the drivers from HP website or the PSP CD that came with the server.
Alternatively you can upgrade to RDP instead of GHOST, RDP is Symantec's offering sold by HP for imaging it's servers.
2. There's some problem with your NIC settings or card if you are trying to PXE boot.
If you are using a floppy drive/ usb HDD, check from BIOS if it is detected.
Posted on Jul 10, 2009
LJ4200 ghosting in middle of page
Perform half test page & check for the ghost image.If half test page not showing ghost image go for 2. (Half test page:while printing open the door, take out the cartridge, remove inside paper gently) 1. check with another cartridge
2. replace teflon sleeve if available or replace fuser assembly..
Nov 29, 2012 | HP LaserJet 4200 Printer
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
I have a Samsung LED 37'' (LE37R88BD) it is just over 2 years old. The colour has changed (very strong reds) and I'm getting image burn from previous channel i.e sports will show the logo or an info bar...
that would be the screen driver failing, the shadow is the memory on the screen control its self the board is on the back of the screen with a lead going to it from the main av board, the board has to be replaced with the same part number, as different ares put different screen in when made you will need the part number from the board and replace it this board with same part number.
Jun 21, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
Nov 24, 2009 | Symantec Norton Ghost 9.0 for PC
I can't get ghost mouse
If you booted on a floppy or other DOS disk to run ghost then you need to load a DOS mouse driver first. Then ghost will find it.
IE boot to DOS, load mouse driver, run ghost.
Note DOS may not detect USB ports so COM or PS/2 mouse is better.
Oct 01, 2009 | Compaq Presario 5000 PC Desktop
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Ghost dell 2500
Just run Ghost in windows and follow the wizard to create a bootable floppy for your hardware
Feb 20, 2008 | Dell PowerEdge 2500 Server
Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Jan 26, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
2,844 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
