Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Phone won't make or receive calls
My screen display seems fine but I can't make or receive calls. If I call a number, say voicemail, the display says Calling Voicemail... and then nothing happens. A day or so before this happened I noticed my phone making strange crackling sounds when I flipped it open.
I didn't drop my phone or anything else that I can think of that might have caused physical damage.
Any ideas? I have the montly insurance. Should I try to get the phone replaced?
  • 113 Answers
SOURCE: razor v3 voicemail
Changing the voicemail message would entirely depend on your provider - how they set it up for you and how you can setup your own message. They must have a specific number you can dial to set your voicemail message. This setting is not available on your phone; rather voicemail messages on the voicemail server of your provider. So, the best way out would be contact the provider. Cheers
Posted on May 10, 2007
SOURCE: voicemail
See this link:
Posted on Jun 03, 2007
  • 125 Answers
SOURCE: No voicemail alert on display
Go to the setting and put voicemail alert from off to on.
Posted on Apr 26, 2008
  • 72 Answers
SOURCE: My voicemail alert is on, but no voicemail.
that is sim company services problem..... u had better consult customer service center................
thank u
Posted on May 13, 2009
  • 223 Answers
SOURCE: voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
Posted on Jun 03, 2009
  • 32 Answers
SOURCE: Home button doesn't work. Calls go to voicemail
dosnt matter..... open your panel and reinsert with a new..........
Posted on Feb 25, 2010
0 characters
1 Points
How to unblock a phone number
From the home screen, tap the Contacts icon.
Tap the desired contact.
Tap the Menu key.
Tap to check the All calls to voicemail box.
The contact is now blocked, and all calls from the caller will go directly to voicemail.
To unblock the contact, with the contact information displayed press the Menu key.
Tap to uncheck All calls to voicemail.
The contact is now unblocked and will now ring normally.
Mar 11, 2016 | Kyocera Cell Phones
Forgot unlock code voicemail kyocera jax
Go to this link...
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Jan 27, 2012 | Kyocera Jax Cell Phone
When I go into my voicemail and put in my password...TWO OF MY CONTACTS also appear on the screen under the password!!! I removed those contacts and then re-entered them into my phone and they reappeared...
Your new phone most likely does not have the bells and whistles to speak the name of the caller when you receive a call.
As for the names appearing when you call voicemail, those names could have similar numbers to your voicemail password. I hope this helps.
May 15, 2011 | Cell Phones
I cannot receive my voicemails. I think there is no number to call to get to my voicemail box. Walmart people will not help me set it up. Theresa
Virgin Mobile
Phone: 888-322-1122
How to reach a live person: Press 0 as soon as you hear "Alex", and keep pressing 0 for each request made for more information.
When you reach a service representative, request assistance with your voice mail set up.
Feb 02, 2010 | Kyocera Cell Phones
When I receive a call I see the phone number but
I have the same problem using Rogers wireless, and I called them about it. It seems that when a call is being made from another cell phone, regardless of whether it is on you contact list or not, it dispays only the number, because it is essentially on their server. If the person hangs up or leaves a voicemail, then any relevent information, such as the contact name associated with the number is displayed on your phone, because that is how your phone deals with that number. In other words, when someone is calling, most likely you will only see the number, and not a lot you can do about it.
Jul 24, 2009 | Nokia E71 Smartphone
Keypad not working during phone call
u'll have to get the keypad checked ...because the connection b/w the buttons and the chipset does seem to be ok.
May 29, 2009 | Motorola Mobility RAZR V3
Voice Message Icon always displaying
The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
May 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Where is the voice record key?
Your network stores the voicemail messages you receive. To listen to your messages, call your voicemail number.
Note: Your service provider may give you additional information about using voicemail.
The phone calls your voicemail phone number. If no
voicemail number is stored, your phone prompts you to
store a number
Jan 22, 2009 | Motorola Mobility RAZR V3
Phone fell off the bed now the screen is white
Your phone display is failed so you need to go to your nearest service center change the display spare regding this problam you can recive the calls and talk to your out going calls but you cant see the display call number
Jun 14, 2008 | LG VX8300 Cellular Phone
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
Oct 18, 2006 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
