Question about Music
Roland xp 50. everything works find except sound
Roland xp 50. everything works find except sound is extremely low. repair man says it can't be replaced. where do i get parts. is my repair man full of it.
Hi friend my xp50 everything work fine but
Not out sound.help me
Posted on Dec 18, 2011
  • Music Master
  • 5,603 Answers
Yes, he is full of it. For parts try Digikey.com, Mouser.com, and AntiqueElectronicSupply.
Posted on Jul 26, 2009
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
MY ROLAND XP-50 HAS NO SOUND WHEN I PRESS THE KEYBOARD
how to hook up roland dm 20 to...computer.
Feb 28, 2013 | Music
I have a roland xp-50 with no power at all. What should I try?
ftp://ftp.roland.co.uk/productsupport/
I would start by checking AC cord is good, look for a blown fuse (BE CAREFUL !!!!) or maybe a defective OFF/ON switch. This keyboard is from the mid 1990's so PLEASE consider this before having it expertly repaired. $$$$$$$
Oct 31, 2012 | Roland Music
Digital pianos
My Roland xp-50 everything work fantastic but no sound out.
Dec 18, 2011 | Music
My adapter or plug is broke and i need a new one. last night i used an adapter from the br-800 and it worked except that when i used the cd option the screen would flicker then it would shut off?
Sounds like the adapter for the 800 isn't quite up to delivering the required current, If it is a standard barrel plug type, you should be able to get a low cost replacement from a local electronics store like Jaycar (Australia) or Radio shack (america) to name a few examples. If possible, take the failed adapter from the 900 in with you when you go to get a replacement as this will help the staff get you the right adapter.
Alternatively you could try ordering one from roland, but that would be a much more pricey venture.
Here is the support site for roland products, it will give you an idea of how to go about having your adapter repaired or replaced.
http://www.rolandus.com/support/?tab=service_repair
Apr 05, 2011 | Roland BR900CD Digital Multitrack Recorder
Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
Mar 07, 2010 | Music
My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Apr 07, 2009 | Music
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
Music Logo
1,726 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
