My phantom spins and lays on the side top of pool and goes in circles?
SOURCE: Hayward phantom will not float fully to the surface
If it has skimmed the top of the pool before try rearranging sections of the hose and make sure all sections of hose can rotate freely.
SOURCE: Why is my phantom cleaner stuck spinning in a
It is most likely that your hose is bent. Check the hose at the hose cleaner end assembly. If you notice that it is bent or warped, lay the hose out in the sun (stretched out) to try to remove the bend. Make sure that you are not storing your hose in a coiled position. This will cause this. It could also be that the pressure though your pool cleaners too high.
SOURCE: my phantom spins in circles
It is is going in circles, it is likely a bent hose. This is common with these pool cleaners if you store your hose in a coiled position. Try laying the hose out on a sunny day and leave it there a few hours to straighten the hose. The running on the side could be a result of the debris bag being too full and heavy. The pressure could also be too high, which would cause both of these problems. Try decreasing the water flow though your cleaner.
SOURCE: My Hayward Phantom pool cleaner has stopped
If the cleaner has no suction, check for obstructions in the debris chamber or throat of the cleaner. Also, check for hose leaks. If the cleaner has suction, but is just not moving properly and is spinning in circles, you most likely have a problem with your hose. It is a common problem with these pool cleaners getting small kinks or bends in their hoses that cause them to move in circles. If you store your cleaner hose in a coiled position, this will make the problem worse. Try laying the hose out in the sun and stretch it slightly. Let it sit for several hours, reconnect, and try it again.
