Question about Hammering
Hi! i have hilti kango te 905!\r\nservice light
Hi! i have hilti kango te 905! service light came on! brushes are fine!
how do i reset the counter switch!
it will start and go for 2-3 seconds and then stop! would welcome any suggestions! cheers!!!
  • 1 more comment
  • caroline Dillon Jun 25, 2009
    i need to find out where int he handle unit the reset counter is! and how to reset it!
    hilti 905 te
    cheers for that! dont have a manual for it! is there a particular sequence after the counter has bein reset ie! holding the trigger and unpluggin it?
    regards
    caroline
  • caroline Dillon Jun 26, 2009
    excellent most helpful
  • 355 Answers
Hello,there is a counter behind the trigger it is made to where when you send it back to hilti, all they do is reset it . You can reset it by taking the handle apart and starting the counter over. They do this because they want you to send it in every time the counter goes off. They say it will usually be under normal use 2 years. Please rate this answer thank you.
Posted on Jun 25, 2009
  • 952 Answers
Take out the brushes.. inspect it, take it back in.. if that doesn't work something is probably overheating from the circuit board. just have it checked by hilti
Posted on Jun 26, 2009
    Brigadier General:
  • 3,917 Answers
Please reset the hammer to factory settings. You can refer to the service manual for the same. Else you need to get in touch with the Hilti Kango Customer service as there is no troubleshooting for this.
Thanks for contacting Fixya
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Hi, My hammer drill HILTI TE76-ATC has service red light on. How can I solve this problem? Thanks
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Sep 25, 2009 | Drills
Hitli te 905 avr. light is on. any idea what it
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 16, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Reprogramming 905 hilti hammerdrill
See if your brushes need changing. You can buy them online and do it yourself. Let me know if you need guidance. Please rate me
Jun 09, 2009 | Hilti Drills
I am the owner of a TE 905 Hilti Jackhammer, Serial No. 234137, I need to purchase replacement brushes and a 14" long flat chisel bit for the Hilti Jackhammer
Did you contact the place you purchased it from? If you still have the paperwork that came with it might have the replacement part #s in one of the flyers. Google the make and model.
May 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti 905 avr starts up slow and uneven speed.
Some of them typically to start up slow. Less wear on the motor. Also make sure you're not using too much drop cord. No more than 100 ft 12/3. May be the brushes if you've had it for awhile. Please rate me
Mar 26, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Mar 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Service light on
When the service light comes on in a normal Hilti all you need to do is replace the brushes,....however on a te-706 there are no brushes to replace, you will need to contact Hilti and have them service it.
Nov 14, 2008 | Drills
Hammering Logo
1,420 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
