Question about Sony NWZB133F MP3 Player
Reception on fm is not very good - Sony NWZB133F MP3 Player
  • 21 Answers
Unfortunately there are only two real ways the reception could be "bad".
Either your MP3 player is a lemon itself (meaning a single defective product, in which case you can return it, if you bought it recently!)....OR, the more likely answer is that MP3 players with FM tuners generally don't have great reception.
I have run into one MP3 player that has pretty good reception, and that is the Zune. It lets you set presets and such as well. Hope that helps!
Posted on Jun 25, 2009
Very poor radio reception
FM reception depends upon having a good antenna matched to the radio. What type of radio are you using, and what are you using for an antenna?
May 02, 2015 | Golf
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
No FM reception on CMT-ED1 Sony shelf system
There is hardly ever an internal FM antenna -- only AM. You'll need at least one of those twin-ax dipole antennas (there's one with every receiver bought).
You can test the concept just by putting a single piece of wire on each antenna terminal -- when you do this reception should improve immediately, but will not be as good as with the dipole antenna.
May 27, 2009 | Sony CMT-ED1 Shelf System
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
FM RADIO DONT WORK..MODERATE AM
hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
Sony NWZB133F MP3 Player Logo
97 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
