Question about Casio EXILIM Card EX-S770 Digital Camera
Problem with the battery
My casio exilim battery won't charge it flashes when i try it. What should I do?
Re: Problem with the battery
I just had this happen to mine too. I think this is a design problem with the camera/battery combination. My camera has a lithium polymer battery (most do now). Lithium polymer (lipo for short) batteries should never be allowed to discharge below about 2.75 volts. Letting the battery discharge below that level will actually permanently damage the cell.
In order to keep that from happening, the device that uses the lipo should have protection circuitry that prevents the battery from falling below that level. I think this is where the Casio camera may have an issue. I found that if I left the battery in the camera for about a month, I was not able to charge it! Lipo battery chargers are more sophisticated than typical charges because lipos need to be charged in a specific way. The first thing a lipo charger does is to check the voltage of the battery you insert into it. If it is below a critical minimum voltage, it will not even charge the battery (Casio charger blinks red continuously).
There are a couple tricks you can do to get the battery to charge, but that's not the important thing here. I think Casio needs to address this issue with our cameras. It would be nice if we could just update the firmware in the camera, but I'm not sure we can do that. I intend to contact Casio to see if they know anything. Based on how many posts like this I have read, I bet they do.
Good luck to use all.
Posted on May 24, 2009
Re: Problem with the battery - Casio EXILIM Card EX-S770 Digital Camera Digital Cameras
Replace the battery
Posted on Nov 06, 2007
0 characters
3 Points
Presently charging my camera, does the red light alway blink?
Base on User's Guide of Casio Exilim EX-S600 Digital Camera, Flashing red light when charging the battery is mean "charge error"
(see the picture)
to overcome some problems that may occur, please refer to the User's Guide of Casio Exilim EX-S600 Digital Camera which can be read here:
good luck :)
Apr 17, 2010 | Casio Exilim EX-S600 Digital Camera
When the battery is in the charger it flashes red & won't charge, have no idea what problem is! Have casio exilim lithium ion NP-20 battery & a casio exilim 7.2 megapixels camera. Can't turn camera...
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Jul 08, 2009 | Casio EXILIM Digital Camera
I have a casio exilim EX-Z60 the mians battery charger flashes constantly red when I place in my battery, but does not charge the battery, can you advise please
I have a casio exilim ex-z60 which I bought 2 yrs ago. I've had problems with my flash going off each time I turned on and off the camera, about 5 months ago. Now the flash does not work. Need help on how to restore the flash bulb or battery in the camera.
Jul 28, 2008 | Casio Exilim EX-Z57 Digital Camera
Battery not charging
I gave my wife also one of the Casio Exilim cameras. She doesn't take a lot of pictures. But so far the battery has not failed us. There might be a chance that your battery has died on you. I suggest you go to Casio and ask them to test the battery. I'm guessing it is the battery that has conked out. If it isn't then you need to have Casio check on your camera.
Jul 06, 2008 | Casio Exilim EX-S500 Digital Camera
Battery light is flashing and it's not charging
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
May 15, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
it wud flash red until it gets fully loaded..its normal...try charging for 90 that is when it is completely charged
Happy to help
HAve a nice day!
May 11, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Casio Exilim battery won't charge
What model of camera? You will probably need to purchase different battery.
Mar 18, 2008 | Casio Exilim EX-Z40 Digital Camera
Not turning on.
this mostly happens due to the motor failure or loose-connection of the wire of motor of lens. or some thing must be stuck inside the shutter or motor..
Mar 09, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
It can't be switched on
What you all need to do is contact Tech Support and tell them you're having trouble with your battery. Casio will send one to you free of charge that has been tested and should work.
Nov 17, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
305 people viewed this question
Top Casio Digital Cameras Experts
Starnley Johnwells
Starnley Johnwells
Are you a Casio Digital Camera Expert? Answer questions, earn points and help others
