Question about Canon PIXMA MP830 All-In-One InkJet Printer
Feed switch & alrm light on
I have a canon mp830 printer, copy, scanner, and the feed switch and alarm light is on
    President:
  • 2,306 Answers
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Posted on Jun 25, 2009
Have a Canon MP830. in the middle of printing, it came up with error code 6A00, and now all it does is flash the alarm light and copy light. how to fix?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#BrochuresAndManuals
I would download the manual for windows 7 and see if the 'alarm and copy light flash' error is listed. I could not find it referred to in the support area of the canonusa.com website. Also, you could call 1-800-OK CANON and talk to a rep. about this problem.
Good luck on this repair.
Feb 06, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer not working..Alarm light & copy light is on...but it doesn't do anything else.
this is an inkjet printe. most inkjet printers hace counters. it must have reached its limit. this is given that the inks are still ok. if it has reached its limit, you will need to have your printer reset with canon.
Jun 19, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon MP830 & I can't print or send a fax Error message 300 - I can't turn off the printer - & it says I have 10% in memory. it is also making a clicking noise
Error No. 300 :
Cause 1: The machine is not ready.
Action : Ensure that the lamp on the Operation Panel lights.
If the lamp on the Operation Panel is off, turn the machine on.
While [COPY] is flashing, the machine is initializing. Wait until [COPY] stops flashing and stays lit.
When the Alarm Lamp lights orange, an error may occur in the machine.
Cause 2 : Machine is not proper connected.
Action : Ensure that the printer cable is securely connected to the computer/
* If using a switching hub or other devices, disconnect the machine and reconnect it directly to the computer and try printing again. If successful, the problem may have been with the device.
* There could also be a problem with the cable(s). Replace the cable and try printing again.
Cause 3 : The name of the machine being used is not selected in the [Printer] pull down menu of the [Print]dialog box.
Action : Select [MP830] from the [Printer] pop-up menu in the [Print] dialog box of the printer driver.
If the [MP830] is not displayed in the printer list, follow the procedure below to confirm the settings.
1) Select [ Print abd Fax Preferences] from the [Printer] pop-up menu.
2) Check that [MP830] is displayed in the screen that is displayed and select the [InMenu] checkbox.
3) If [MP830] is not displyed, click [+] to add a printer.
If [MP830] is not displayed, install the MP Drivers again referring to the Easy Setup Instructions for the operations.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon MP830 Printer will mot work. Alarm blinking and copy light blinking . How do i FIX? Dr.s' office...help!!
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer keeps showing an error 6A00 on LCD screen
There is one solution you can reinstall software of printer
May 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
SCANNER LOCK SWITCH IS ON...HOW TO GET IT OFF
Open the Document Cover - On the Front - Left hand side of the frame is the scanner lock switch.
Jan 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon mp830
hi,
its next to the scanner glass, open the top up like you would copy and its there to the left
hope this helps
Oct 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
133 people viewed this question
old marine
old marine
