Question about Acer Aspire One Netbook 8.9" Notebook
A problem has been detected and windows has been shut down to prevent damage to your computer
  • 30 Answers
Your computer is probably overheating.
Posted on Jun 25, 2009
4 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: presario 2200 laptop won't start up-goes to
Did you do this below?
This is called the BSOD (blue screen of Death) this usually occurs if you have recently installed either a new piece of hardware with a driver that has conflicted with Windows.
1. Unplug all you USB peripherals while the PC is shutdown
2. Press F8 while the PC is booting up its difficult to know when to do it so I usually press it twice with 5 seconds between presses.
3. Select last known good configuration and see if your PC will start this might be all that it needs.
If this fails unless you have a boot CD that allows you to recover the DOS or on some laptops like Evesham they have PC angel installed I am not sure if the Compaq Presario has this but you can use Hirens Boot CD or some other to try and restore the files,
I am sure that the CAB files that are required will still be on the laptop unless someone has removed then to save space.you may have to take it back to factory defaults, you will loose all installs and documents though its a bit drastic but it should get you back up and running.
Hope this helps please rate my post if it helps you.
Posted on Oct 15, 2009
Testimonial: "IT DIDN'T HELP BUT I DO THANK YOU"
  • 80 Answers
SOURCE: -(a problem has been detected and windows has been
change RAM if its error in blue screen
Posted on Nov 14, 2009
  • 3 Answers
SOURCE: Unable to get into safe mode
To Repair Blue Screen and Safe Mode
Posted on Mar 13, 2011
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
this error comes from hardware .restart the system and press F8 key in start then choose safemode option and log on the system.then remove the software which you install on the system before error.try it it solve this problem......rate it
Apr 16, 2009 | Computers & Internet
A problem has been detected and windows has been shut down to prevent damage to your computer.
Try to do a system restore and see if it works fine..
Try to log on to safe mode using F8 and then choose system restore.
Apr 15, 2009 | Computers & Internet
Blue screen ,technical info,
try reinstalling windows
Apr 02, 2009 | Computers & Internet
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Windows has shut down my computer. It said the following: A problem has been detected and windows has been shut down to prevent damage to your computer. I need to know how to get out of this
Try to start in safe mode. On some computers it is F5 or F8 during boot. Hitting delete while booting will open setup which may get you to safe mode. Once there, you need to do virus checking, and stuff like that.
Aug 18, 2008 | Computers & Internet
Computer
windows are corupted somebody has forced ur computer to shutdown manually u need to repair ur windows first by the windows cd or needs to perform clean installation
May 20, 2008 | Gateway GT5220 PC Desktop
Acer Aspire One Netbook 8.9" Notebook Logo
184 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
